Component Viewer Error: Failed to parse RTX5.scvd
Hello All,
I am following the tutorial for implementing CMSIS using Keil uVision v5.20:
https://www.keil.com/pack/doc/CMSIS/RTOS2/html/rtos2_tutorial.html
On "Exercise 1 - A First CMSIS-RTOS2 Project" when I perform step "Start the Debugger" to debug, I get the following error and the component viewer does not display:
Expression: '0'
E221: Semantic check - <event 'RTX5 RTOS'>: 'id' is missing
Expression: '0xFA00 + 0x18'
E221: Semantic check - <event 'RTX5 RTOS' <until="Inactive">: undefined 'until' event name
E221: Semantic check - <event 'RTX5 RTOS' <until="Ready">: undefined 'until' event name
E221: Semantic check - <event 'RTX5 RTOS' <until="Running">: undefined 'until' event name
E221: Semantic check - <event 'RTX5 RTOS' <until="Blocked">: undefined 'until' event name
E221: Semantic check - <event 'RTX5 RTOS' <until="Not-running">: undefined 'until' event name
E221: Semantic check - <event 'RTX5 RTOS' <until="Free">: undefined 'until' event name
E221: Semantic check - <event 'RTX5 RTOS' <until="Used">: undefined 'until' event name
E221: Semantic check - <event 'RTX5 RTOS' <until="Error">: undefined 'until' event name
E402: Failed to parse - File: 'C:\Keil_v5\ARM\PACK\ARM\CMSIS\5.6.0\CMSIS\RTOS2\RTX\RTX5.scvd' - one or more errors while parsing xml content
Load "C:\\Projects\\rtx_stm32l073_test_2\\Objects\\merlin_hh_sm.axf"
Here is my RTX5.scvd:
0
