I see the below folder folder structure after installing 5.37 . ARMCC folder is missing when I install 5.37.
Is it a new update?? Where can I find armcc.exe??
See:
Arm Compiler 5 not available in Keil MDK
Thank you. In that case 5.36 should be same as 5.37. But I see the compiler with 5.36. Is it being removed from 5.37??
Exactly, our KBA (see above) explains reasons
Hi, I need to know how to download latest armcc as the latest mdk version excluded. Is there any link from where I could download the compiler??
Carefully follow:
"Arm Compiler 5 not available in Keil MDK"
https://developer.arm.com/documentation/ka005073/latest
