Hi all,
I tried the rfft for q31 fixed point. The scale of the output is different than what I thought.
I use 32 pt rfft. Input is constant 2^10=1024 (in Q31). The DC term output should be 2^10 * 2^5 / 2^4 = 2048 (in Q5.27), where multiplication of 2^5 is due to 32 pt fft, and division of 2^4 is due to input scale in each stage as mentioned below. All the terms other than DC one should be zeros.
However, my result for DC term is 1024 + j 0 (I expect 2048+j 0).
Anyone has any idea?
Paul
Code and results are attached.
Code:
For N point real data, you can use N point complex fft as you mentioned via adding imaginary part as zero. However if you use real fft, it actually calls for N/2 complex fft with some tricks.So the computational complexity is reduced.
But this is irrelevant to my scaling question…
