I work with STM32F4LP5 chip and Keil USB device stack.
I configure USB-HID with HID_REPORT_DESCRITOR to 63 and a specific descriptor as follow :
#define KBD_REPORT_DESC_SIZE 63Uconst uint8_t usbd_hid0_report_descriptor[KBD_REPORT_DESC_SIZE] ={0x05, 0x01, // Usage Page (Generic Desktop),0x09, 0x06, // Usage (Keyboard),0xA1, 0x01, // Collection (Application),0x75, 0x01, // Report Size (1),0x95, 0x08, // Report Count (8),0x05, 0x07, // Usage Page (Key Codes),0x19, 0xE0, // Usage Minimum (224),0x29, 0xE7, // Usage Maximum (231),0x15, 0x00, // Logical Minimum (0),0x25, 0x01, // Logical Maximum (1),0x81, 0x02, // Input (Data, Variable, Absolute),//;Modifier byte0x95, 0x01, // Report Count (1),0x75, 0x08, // Report Size (8),0x81, 0x03, // Input (Constant),//;Reserved byte0x95, 0x05, // Report Count (5),0x75, 0x01, // Report Size (1),0x05, 0x08, // Usage Page (LEDs),0x19, 0x01, // Usage Minimum (1),0x29, 0x05, // Usage Maximum (5),0x91, 0x02, // Output (Data, Variable, Absolute),//;LED report0x95, 0x01, // Report Count (1),0x75, 0x03, // Report Size (3),0x91, 0x03, // Output (Constant), ;LED report?// padding0x95, 0x06, //................// Report Count (6),0x75, 0x08, // Report Size (8),0x15, 0x00, // Logical Minimum (0),0x25, 0x68, // Logical Maximum(104),0x05, 0x07, // Usage Page (Key Codes),0x19, 0x00, // Usage Minimum (0),0x29, 0x68, // Usage Maximum (104),0x81, 0x00, // Input (Data, Array),0xc0 // End Collection};
In main, i do USB initialization layer :
USBD_Initialize (0); // USB Device 0 Initialization USBD_Connect (0); // USB Device 0 Connect
PC HOST view and is ok to mangage keyboard USB-HID : Ok
Then the first call to USBD_HID_GetReportTrigger() function works fine and send a correct 8 bytes flow to HOST (pc) :
USBD_HID_GetReportTrigger(0, 0, (uint8_t *)&keyBoardHIDsub, sizeof(keyBoardHIDsub) );
But STM32 won't send 8 bytes to release the key and send only one 0 byte over USB link and HOST repeat the key in loop.
The second call to USBD_HID_GetReportTrigger give 0x23 error : usbDriverBusy
Why ?
Regards,
G.Grange
Is source of USB_CM3.lib are available ?
Is a valid example using USBD stack for keyboard device is available ? (i just find mouse example)
G.Grange (ggrange@centralp.fr)
I had never heard of USB_CM3.lib before this post, but might this help?https://github.com/x893/CMSIS-DAP/tree/master/Firmware/STM32/USBStack
Thanks for samples, but i can't replace USB_CM3_L.lib by theses sources.
I finally find the bug, You can use HID management for keyboard if you generate a correct keyboard report profil. I define 'User Provided HID Report Descriptor" as follow :
// User Provided HID Report Descriptor// for standard keyboard (size of this descriptor is 63 bytes)// From www.microchip.com/.../m816038.aspxextern const uint8_t usbd_hid0_report_descriptor[];const uint8_t usbd_hid0_report_descriptor[63] = { HID_UsagePage(HID_USAGE_PAGE_GENERIC), // 0x05, 0x01, // Usage Page (Generic Desktop), HID_Usage(HID_USAGE_GENERIC_KEYBOARD), // 0x09, 0x06, // Usage (Keyboard), HID_Collection(HID_Application), // 0xA1, 0x01, // Collection (Application), HID_UsagePage(HID_USAGE_PAGE_KEYBOARD), // 0x05, 0x07, // Usage Page (Key Codes); HID_UsageMin(224), // 0x19, 0xE0, // Usage Minimum (224), HID_UsageMax(231), // 0x29, 0xE7, // Usage Maximum (231), HID_LogicalMin(0), // 0x15, 0x00, // Logical Minimum (0), HID_LogicalMax(1), // 0x25, 0x01, // Logical Maximum (1), HID_ReportSize(1), // 0x75, 0x01, // Report Size (1), HID_ReportCount(8), // 0x95, 0x08, // Report Count (8), HID_Input(HID_Variable), // 0x81, 0x02, // Input (Data, Variable, Absolute), ; Modifier byte HID_ReportCount(1), // 0x95, 0x01, // Report Count (1), HID_ReportSize(8), // 0x75, 0x08, // Report Size (8), HID_Input(HID_Constant), // 0x81, 0x01, // Input (Constant), ; Reserved byte HID_ReportCount(5), // 0x95, 0x05, // Report Count (5), HID_ReportSize(1), // 0x75, 0x01, // Report Size (1), HID_UsagePage(HID_USAGE_LED_DO_NOT_DISTURB), // 0x05, 0x08, // Usage Page (Page# for LEDs), HID_UsageMin(1), // 0x19, 0x01, // Usage Minimum (1), HID_UsageMax(5), // 0x29, 0x05, // Usage Maxmimum (5), HID_Output(2), // 0x91, 0x02, // Output (Data, Variable, Absolute), ; LED report HID_ReportCount(1), // 0x95, 0x01, // Report Count (1), HID_ReportSize(3), // 0x75, 0x03, // Report Size (3), HID_Output(HID_Constant), // 0x91, 0x01, // Output (Constant), ; LED report padding HID_ReportCount(6), // 0x95, 0x06, // Report Count (6), HID_ReportSize(8), // 0x75, 0x08, // Report Size (8), HID_LogicalMin(0), // 0x15, 0x00, // Logical Minimum (0), HID_LogicalMax(101),// 0x25, 0x65, // Logical Maximum (101), HID_UsagePage(HID_USAGE_PAGE_KEYBOARD), // 0x05, 0x07, // Usage Page (Key Codes), HID_UsageMin(0), // 0x19, 0x00, // Usage Minimum (0), HID_UsageMax(101), // 0x29, 0x65, // Usage Maximum (101), HID_Input(0), // 0x81, 0x00, // Input (Data, Array), ; Key arrays (6 bytes) HID_EndCollection, // End Collection};
This point is close.
Thanks for support,
This point is now close.
If you need to check a report descriptor, this site can be useful.
https://eleccelerator.com/usbdescreqparser/
