RTC_IRQHandler never entered
Hi everybody,
I want to use the the RTC (Real Time Counter) interrupt in my code. To do it, I need to program the associated RTC_IRQHandler function which is declared in the startup-ARMC0plus.s file.
; * @file     startup_ARMCM0plus.s
; * @brief    CMSIS Core Device Startup File for
; *           ARMCM0plus Device Series
; * @author    S.Wright
; * @version   v1.1.0
; * @date      2018/06/19
; * @attention changes from original startup_ARMCM0plus.s are copyright: 2016..2018, Cobham AES
; * @note
;/* Copyright (c) 2012 ARM LIMITED
;   All rights reserved.
;   Redistribution and use in source and binary forms, with or without
;   modification, are permitted provided that the following conditions are met:
;   - Redistributions of source code must retain the above copyright
;     notice, this list of conditions and the following disclaimer.
;   - Redistributions in binary form must reproduce the above copyright
;     notice, this list of conditions and the following disclaimer in the
;     documentation and/or other materials provided with the distribution.
;   - Neither the name of ARM nor the names of its contributors may be used
;     to endorse or promote products derived from this software without
;     specific prior written permission.
;   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
;   AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
;   IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
;   ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
;   LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
;   CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
;   SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
;   INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
;   CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
;   ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
;   POSSIBILITY OF SUCH DAMAGE.
;//-------- <<< Use Configuration Wizard in Context Menu >>> ------------------
; <h> Stack Configuration
;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
; Stack_Size      EQU     0x00000400   #### TEST ONLY -- S.Wright, 2017/10/12
Stack_Size      EQU     0x00000800
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; <h> Heap Configuration
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
; Heap_Size       EQU     0x00000C00
Heap_Size       EQU     0x00001000                 ; #### TEST ONLY -- S.Wright, 2017/07/06
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
__Vectors      ; Reset SP/vector
                DCD     __initial_sp              ; -16: Top of Stack
                DCD     Reset_Handler             ; -15: Reset Handler
                ; Internal Interrupts
                DCD     NMI_Handler               ; -14: NMI Handler
                DCD     HardFault_Handler         ; -13: Hard Fault Handler
                DCD     0                         ; -12: reserved
                DCD     0                         ; -11: reserved
                DCD     0                         ; -10: reserved
                DCD     0                         ;  -9: reserved
                DCD     0                         ;  -8: reserved
                DCD     0                         ;  -7: reserved
                DCD     0                         ;  -6: reserved
                DCD     SVC_Handler               ;  -5: SVCall Handler
                DCD     0                         ;  -4: reserved
                DCD     0                         ;  -3: reserved
                DCD     PendSV_Handler            ;  -2: PendSV Handler
                DCD     SysTick_Handler           ;  -1: SysTick Handler
                ; External Interrupts: UT32M0R500-specific
                DCD     MBEA_IRQHandler           ;   0: MBEA
                DCD     DUALTIMER0_IRQHandler     ;   1: DualTimer0
                DCD     DUALTIMER1_IRQHandler     ;   2: DualTimer1
                DCD     PWM_IRQHandler            ;   3: PWM
                DCD     RTC_IRQHandler            ;   4: RTC
                DCD     GPIO0_16_IRQHandler       ;   5: GPIO16 [GPIO1, Pin 0]
                DCD     GPIO0_17_IRQHandler       ;   6: GPIO17 [GPIO1, Pin 1]
                DCD     GPIO0_18_IRQHandler       ;   7: GPIO18 [GPIO1, Pin 2]
                DCD     GPIO0_19_IRQHandler       ;   8: GPIO19 [GPIO1, Pin 3]
                DCD     GPIO0_20_IRQHandler       ;   9: GPIO20 [GPIO1, Pin 4]
                DCD     GPIO0_21_IRQHandler       ;  10: GPIO21 [GPIO1, Pin 5]
                DCD     GPIO0_22_IRQHandler       ;  11: GPIO22 [GPIO1, Pin 6]
                DCD     GPIO0_23_IRQHandler       ;  12: GPIO23 [GPIO1, Pin 7]
                DCD     Default_Handler           ;  13: reserved
                DCD     UART0_IRQHandler          ;  14: UART0
                DCD     UART1_IRQHandler          ;  15: UART1
                DCD     CAN0_IRQHandler           ;  16: CAN0
                DCD     CAN1_IRQHandler           ;  17: CAN1
                DCD     I2C0_IRQHandler           ;  18: I2C0
                DCD     I2C1_IRQHandler           ;  19: I2C1
                DCD     SPI_IRQHandler            ;  20: SPI
                DCD     ADC_IRQHandler            ;  21: ADC
                DCD     GPIO0_ALL_IRQHandler      ;  22: GPIO0 combined
                DCD     GPIO1_ALL_IRQHandler      ;  23: GPIO1 combined
                DCD     GPIO2_ALL_IRQHandler      ;  24: GPIO2 combined
                DCD     Default_Handler           ;  25: reserved
                DCD     Default_Handler           ;  26: reserved
                DCD     Default_Handler           ;  27: reserved
                DCD     Default_Handler           ;  28: reserved
                DCD     Default_Handler           ;  29: reserved
                DCD     Default_Handler           ;  30: reserved
                DCD     Default_Handler           ;  31: reserved
__Vectors_End
__Vectors_Size  EQU     __Vectors_End - __Vectors
                AREA    |.text|, CODE, READONLY
; Reset Handler
Reset_Handler   PROC
                EXPORT  Reset_Handler             [WEAK]
                IMPORT  SystemInit
                IMPORT  __main
                LDR     R0, =SystemInit
                BLX     R0
                LDR     R0, =__main
                BX      R0
                ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler               [WEAK]
                B       .
                ENDP
HardFault_Handler\
                PROC
                EXPORT  HardFault_Handler         [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler               [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler            [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler           [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT MBEA_IRQHandler           [WEAK]
                EXPORT DUALTIMER0_IRQHandler     [WEAK]
                EXPORT DUALTIMER1_IRQHandler     [WEAK]
                EXPORT PWM_IRQHandler            [WEAK]
                EXPORT RTC_IRQHandler            [WEAK]
                EXPORT GPIO0_16_IRQHandler       [WEAK]
                EXPORT GPIO0_17_IRQHandler       [WEAK]
                EXPORT GPIO0_18_IRQHandler       [WEAK]
                EXPORT GPIO0_19_IRQHandler       [WEAK]
                EXPORT GPIO0_20_IRQHandler       [WEAK]
                EXPORT GPIO0_21_IRQHandler       [WEAK]
                EXPORT GPIO0_22_IRQHandler       [WEAK]
                EXPORT GPIO0_23_IRQHandler       [WEAK]
                EXPORT UART0_IRQHandler          [WEAK]
                EXPORT UART1_IRQHandler          [WEAK]
                EXPORT CAN0_IRQHandler           [WEAK]
                EXPORT CAN1_IRQHandler           [WEAK]
                EXPORT I2C0_IRQHandler           [WEAK]
                EXPORT I2C1_IRQHandler           [WEAK]
                EXPORT SPI_IRQHandler            [WEAK]
                EXPORT ADC_IRQHandler            [WEAK]
                EXPORT GPIO0_ALL_IRQHandler      [WEAK]
                EXPORT GPIO1_ALL_IRQHandler      [WEAK]
                EXPORT GPIO2_ALL_IRQHandler      [WEAK]
MBEA_IRQHandler
PWM_IRQHandler
RTC_IRQHandler
GPIO0_16_IRQHandler
GPIO0_17_IRQHandler
GPIO0_18_IRQHandler
GPIO0_19_IRQHandler
GPIO0_20_IRQHandler
GPIO0_21_IRQHandler
GPIO0_22_IRQHandler
GPIO0_23_IRQHandler
UART0_IRQHandler
UART1_IRQHandler
CAN0_IRQHandler
CAN1_IRQHandler
I2C0_IRQHandler
I2C1_IRQHandler
SPI_IRQHandler
ADC_IRQHandler
                B       .
                ENDP
                ALIGN
; User Initial Stack & Heap
                IF      :DEF:__MICROLIB
                EXPORT  __initial_sp
                EXPORT  __heap_base
                EXPORT  __heap_limit
                ELSE
                IMPORT  __use_two_region_memory
                EXPORT  __user_initial_stackheap
__user_initial_stackheap PROC
                LDR     R0, =  Heap_Mem
                LDR     R1, =(Stack_Mem + Stack_Size)
                LDR     R2, = (Heap_Mem +  Heap_Size)
                LDR     R3, = Stack_Mem
                BX      LR
                ENDP
                ALIGN
                ENDIF
                END
First, I initialized the RTC in a counter.c file as follow. It wrap when it reaches 0x1FFFFFFF and the interruption must be risen.
#define C_RTC_PLACE_BIT_3                     3
#define C_RTC_PLACE_BIT_2                     2
#define C_RTC_PLACE_BIT_1                     1
#define C_RTC_PLACE_BIT_0                     0
#define C_INIT_RTC_WEN                        1 // RTC wrap enable
#define C_INIT_RTC_EN                         1 // Start RTC
#define C_INIT_RTC_MASK                       0 // no mask on interrupts
#define C_INIT_RTC_IEN                        1 // interrupts enable
#define C_INIT_COUNTER_CONTROL_MASK           ((C_INIT_RTC_WEN<<C_RTC_PLACE_BIT_3) | (C_INIT_RTC_EN<< C_RTC_PLACE_BIT_2) | (C_INIT_RTC_MASK<<C_RTC_PLACE_BIT_1)  | (C_INIT_RTC_IEN<<C_RTC_PLACE_BIT_0) )
void counterInit(void)
	NVIC_SetPriority (RTC_IRQn, 0);
	NVIC_EnableIRQ(RTC_IRQn);
	s_counter->counterMatchRegister = 0x1FFFFFFF;
	s_counter->counterControlRegister = C_INIT_COUNTER_CONTROL_MASK;
I also programmed the RTC_IRQHandler in the same file
void RTC_IRQHandler(void);
	volatile t_int32u l_readEOIRegister;
	s_extraBitsCounter++;                                  // increment a counter
	l_readEOIRegister = s_counter->endOfInterruptRegister; // read EOI register to clear it
	NVIC_ClearPendingIRQ(RTC_IRQn);
However, when the counter wraps, the interrupts is risen but the program never enter the RTC_IRQHandler function.
What could be wrong ?
Thank you for your help.
Best regards.
Rémi G.
  • Are you sure that your implementation of the IRQ handler is being included in the build?  Check your .map file.  If the address of the RTC handler is the same as all the other defaults, your impl has not been included.  I have seen this issue before, with the Keil IDE I think.
  • My function is defined in the image symbol two times :
    As follow in the Local Symbols
        i.RTC_IRQHandler                         0x20000384   Section        0  counter.o(i.RTC_IRQHandler)
    and as follow in Global Symbols
    RTC_IRQHandler                           0x20000385   Thumb Code    34  counter.o(i.RTC_IRQHandler)
    Finally it is defined in the Memory Map of the image as follow
    0x20000384   0x20000384   0x00000030   Code   RO          234    i.RTC_IRQHandler    counter.o
    What could be the error ?
  • Maybe the PRIMASK register is blocking interrupts.
  • Thank you for your help but according to keil, the PRIMASK is desactivated.
    And keil do something strange. When I run the program, everything runs correctly (except the interrupt). When I stop it, and re run it, it is stuck in this assembly line. When I run step by step, this problem never occurs.
    0x0000022A E7FE      B        0x0000022A
    Can the issues have a link ?
    Best regards
  • This is a long shot,  but thought it might help.  I noticed that your RTC handler is at address 20000384.  I work on CM3, your system appears to be a CM0plus? I think that on both systems, flash is at 0 and ram starts at 20000000.  If correct, your handler might be being placed in RAM.  Do you have anything like __ramfunc in your code, or perhaps your handler is marked as going in a .ram section.
    If your entire vector table is somehow being put into ram too, you'll have to re-locate your VTOR. If not, perhaps ram-located funcs cannot be in the vector table? Could the branch distance be too large, and you might need 'veneers', handled by the linker?
    I just think your 20000384 address is a bit suspicious, as the address of an ISR that is.
  • the 20th vector table entry holds the address that will be called when an RTC_IRQ happens
    Make sure address 0x00000050 has 0x20000384,  If it has 0x0000022A, it is not using your routine but the default routine (which is branch to 0x0000022A)
    It is is 0x20000384, you need to check which interrupt is actually active at this point.
  • Thank you for all the answers.
    I didn't defined the System Control Space (SCS) and so the System Control Block (SCB) and the NVIC.
    Finally, I declared the Interrupt Vector at the right SRAM adress... and It works ! (see core_cm0plus.h)
