Dear helpful community,
I am getting hardfault escalated from imprecise bus fault originated from the ethernet interface thread based on the MDK-Plus network middleware (v7.14), which I have no clue how to debug.
Have double checked all the configurations (pins, PHY_ADDRESS, etc ) to be ok. The network core thread was started and ran...
I have enabled the debug variant of the middleware and streamed the debug info to EventRecorder via STDIO but did not find anything from the Network component.
All the rest of the firmware works well without the network core and interface running.
Appreciate any tips or suggestions given.
Thanks in advance.
BR,
SengTak
Hi SengTak,
take a look on how to debug faults here: https://www.keil.com/appnotes/files/apnt209.pdf
Best regards, Milorad
Hi Milorad,
Thanks but not helpful.
The problem is I can't trace the fault to the source of the code which is caused by the closed-up MDK middleware
