Hi everybody,
i am using Keil uVision 5.35 and i am using Git to share my project with my teammates.
Is it possible to integrate an editorconfig to Keil IDE? Or is there any useful Plugin?
I was wondering that i can´t find any similar topic in this forum, isn´t it a problem that affects you too?
Thanks and greetings
SteveB2g
Please take a look at:
"Configuring the Editor"
https://www.keil.com/support/man/docs/uv4/uv4_ui_config_editor.htm
as part of:
https://www.keil.com/support/man/docs/uv4/uv4_dg_configsettings.htm
If you want to try something different, look up Keil Assistant. I haven't used it myself but it's an interesting idea.
