I try to validate my CMSIS pack and new flash programming algorithm(The function has been properly verified). So I create a new project with this CMSIS pack and load the application to Flash using the new flash programming algorithm.
(Memory: 8M Flash from 0x0000 0000 to 0x0080 0000. 2M RAM from 0x2000 0000.)
When I online debug in Keil-MDK after load application.axf to Flash.
Unfortunately, the application is stuck in an infinite loop after clicking Start Debug Session.
Weirdly, the address is the Start address of Ram for Algorithm 0x2008 0000.
Normally, SP and PC values should be reset to the correct value stored in 0x0000 0000 and 0x0000 0004 of my application as follow:
The application will run OK but cannot be online debugged normally, such as reset to stack point init or system init.
2. Add the initialization file and load SP/PC value from 0x0000 0000/0x0000 0004.
The same thing happened. The application will run OK but cannot be online debugged normally.
Please help me if you have any ideas!
Thanks a lot!
- What is the MDK version in use?
- What is the target in use?
- Compare with an example project that might be offered by the Pack Installer:
https://www2.keil.com/mdk5/packinstaller/
- https://www.keil.com/support/man/docs/uv4/uv4_debugging.htm
MDK version is v5.35
Target is MPS3 FPGA board.
Thanks!
