Is there a way to set individual or even all files in a project to read-only (within the IDE)? For example in Notepad++, if one right-clicks on a tab (filename tab at the top) it's possible to set a file to read-only. I am porting a LOT of different projects and files and code and it would be helpful to do this from within the IDE.
Thanks,
GB
Edit: I am using IDE-Version: µVision V5.34.0.0
uVision (the IDE of Keil MDK) does not offer to modify file attributes.
Related:
"File, Group, and Component Attribute Icons"
www.keil.com/.../uv4_ca_filegrp_att.htm
