Keil uVision 5.36 not save file and open a file in blank after some compilations. It's very uncomfortable to have restar uVision or use a external editor.
I am using windows 11, but the problem does even with windows 7 x86. I have deactivated the antivirus to the folders, to the executable, I put uVision in firewall, I have installed it in several versions of windows, I have excluded it from analysis, I have tried thousands of combinations and nothing seems to solve the problem.
I usually have the projects in the paid version of OneDrive, but I have also tried moving the file to a clean place, on ReFs, NTFS, FAT32, exFAT disks and the problem persists. I have disabled OneDrive, and the problem persists.
It is very uncomfortable to work like this, is there a solution?
Thanks Very Much!!!!!
After two compilations in a row, it becomes impossible to edit within Keil, this situation is very uncomfortable.
