I am using MK60DX256VLL10 in a circuit. After soldering the controller onto the designed board, I tried to download my code into the controller using Ulink Pro Debugger using Keil MDK. But i encounter "Kinetis Device is Locked. Do you want to unlock it? Mass erase will be executed" to which I press OK. After few seconds, "Invalid ROM table" appears and erase is not performed.
To be cear, the same code is used in another board where same controller is used and in that board, I am able to doanload my code wihtout any "lock isssue" or "invalid rom table" issue.
See i.e.:
"ULINK: Unlocking NXP/Freescale Kinetis Memory With a Keil ULINK2"
developer.arm.com/.../latest
Already done this but this did not help
