I am running the following code, compiled (with no optimisation) by ARMCC 5.06u7, in MDK 5.34.
The four 1B variables `ext_flag`, `coarse_bytes`, `fine_bytes`, and `timecode_id` are initialised to zero, not the values given. If I set them to those values again after initialisation, they remain zero.
If I make those variables static, the variables take on nonzero values, but not the ones given here.
It is so strange, and I have checked my sanity with two other programmers.
Has anyone encountered this behaviour before? Is this the Keil debugger, or the ARM compiler?
T_Result result = RESULT_OK;
T_Utils_Result utils_result = UTILS_RESULT_OK;uint8_t ext_flag = 0x80;uint8_t coarse_bytes = 0x0C;uint8_t fine_bytes = 0x03;uint8_t timecode_id = 0x70;ext_flag &= buffer[0];ext_flag >>= POSITION_EXT_FLAG;coarse_bytes &= buffer[0];coarse_bytes >>= POSITION_COARSE_BYTES;fine_bytes &= buffer[0];fine_bytes >>= POSITION_FINE_BYTES;if ((NO_EXTENDED_PREAMBLE != ext_flag) || (COARSE_BYTES != coarse_bytes) || (FINE_BYTES != fine_bytes)){ result = RESULT_INVALID_PACKET;}
Here is the disassembly, which is clearly not intended:```
0x0000593A E92D5FFC PUSH {r2-r12,lr}0x0000593E 4604 MOV r4,r00x00005940 4688 MOV r8,r10x00005942 4615 MOV r5,r2 95: T_Result result = RESULT_OK; 0x00005944 2700 MOVS r7,#0x00 96: T_Utils_Result utils_result = UTILS_RESULT_OK; 97: 0x00005946 46B9 MOV r9,r7 98: uint8_T ext_flag = 0x80; 0x00005948 46BA MOV r10,r70x0000594A 2000 MOVS r0,#0x00 99: uint8_T coarse_bytes = 0x0C; 0x0000594C 9001 STR r0,[sp,#0x04]0x0000594E 4683 MOV r11,r0 100: uint8_T fine_bytes = 0x03; 0x00005950 2600 MOVS r6,#0x000x00005952 9000 STR r0,[sp,#0x00]
Any ideas?
What is the value of buffer[0]?
0x1e
If it were 0, then I'd suspect optimisation, even though it's switched off
But I should say now that the problem disappeared after I restarted Keil. No changed settings - just a restart.
