i am using ds80c320 ,
I am Trying to compile and got Syntax error in Structure definition,
i cant understand the issue,kindly help me figure out the issue,
Here is the error..
See: https://www.keil.com/support/man/docs/c51/c51_c141.htm
or: https://community.arm.com/support-forums/f/keil-forum/34547/error-c141
(other related posts can be found when entering C141 at the Search bar)
The compiler can't find your welnet header wn_8051.h
