Memory Protection Unit in Keil IDE debugger not working
Hello I have a question regarding MPU and uKeil.
So basically I have following piece of code for testing read only permission:
static uint32_t test[128] __attribute__((aligned(32)));
static void test_mpu(void){
	MPU->RNR  = 0;
	MPU->RBAR = (uint32_t)test;
	MPU->RASR = (MPU_AP_RO<<MPU_AP_Pos) | (MPU_ATTR_SRAM<<MPU_ATTR_Pos) | (MPU_REGION_SIZE_32b<<MPU_SIZE_Pos) | MPU_ENABLE;
	SCB->SHCSR |= SCB_SHCSR_MEMFAULTENA_Msk;
	MPU->CTRL = 0x05;
	test[0] = 0x99; /** trigger fault */
void MemoryManagement_Handler(void){
  uint32_t i = 0;
  while(1){
    __asm("bkpt 1");
    ++i;
And the problem it doesn't trigger any fault, but the thing that confuse me, is that when I upload the same code using segger embedded studio everything is working fine, I end up in mem handler with address in MMFAR register.
So do I have to do some additional settings configuration in keil debugger itself or there's another way to fix this, because I prefer Keil over SES and don't really want switch to this second one.
Also I'm using nrf52840 with cortex m4 cpu and j-link.
Thanks in advance for any thoughts.
  • Hi bursztyn12,
    I have tried your code, and I have observed 2 things.
    1. Because your test variable was not specified as volatile, Arm Compiler at optimization level O3 did not even store the value to the memory it just had it in a register. You can force the write access by specifying test to be volatile:
    static volatile uint32_t test[128] __attribute__((aligned(32)));
    2. When single stepping with J-Link on board debugger the memory fault was not triggered, however if I just run the code with the debugger then the memory fault was triggered.
    Best regards, Milorad
  • I had the compiler optimization level set to 0, so it wasn't the cause of this problem, but I can confirm your second point (even without volatile, at -O0) just running and not single stepping triggered handler, so thank you very much Milorad for your time and suggestion.
    However do you know what could cause, at least for me, this kind of strange behaviour, because like I said in SES even with single stepping memory fault is trigger correctly, it's some debugger software differences between those two or there's another explanation?
