HiRight click on a file in uVision(5.33) 'Project' window shows item 'Translate file.c' which (when clicked) compiles 'file.c' only.Is there a way to map a shortcut key to that command ? Eg translate currently active/open file in the 'Editor' window ?
Thanks for help
You should see this option in the Project menu, which also shows it is mapped to Ctrl+F7,
Thank you Ronan, I did not know it was also there (and mapped). But it is not mapped in uVision 5.33 and neither it is on the list in 'edit->configuration->shortcut keys'. Maybe after I update to the latest MDK. Very depressing.
You should see "Project: Translate" in the "Configuration -> Shortcut Keys" list:
Sorted. Thanks Andreas.
