Go To Definition is a game of luck
the usage of the "Go To Definition" function is one of the most important function of the IDE for me. Working with software I`m using this function hundreds of times per day. In the past (up to 5.24.2) this was working without any problems. Today (5.35.0) I have have so much problems with this function. In 50% of all cases it works fine as usual. In the other 50% I`m always getting this enervating "No browse info for symbol in this context".
- yes, I enabled the creation of the browse information in the options
- yes, I rebuild the complete code
- yes, the header file with the searched information is included (open document and ctrl-f-search will find)
- yes, I hoped that with 5.35 the problem would be silently fixed ... but it does not
I can not imagine that such a great IDE like uvision has so elementary bugs ... the mistake must be on my side. Where is my fault ?
Please help !
friendly regards
Recently
  • I see the exact behavior (and have done that since the feature was introduced).
    I have yet to figure out why and when i happens, seems to be very random
  • Please open a Support Ticket according to:
       https://www2.keil.com/support/silver?P=&V=&S=
    and attach a demonstrating project together with a detailed summary.
  • I reported the problem to support and was asked to upload my source code. However, my company forbade me to do so. Then there was no more recation and meanwhile my request has also been deleted. I have now updated to the latest version and can only say that the problem is still there. I find it extremely embarrassing that such basic functions do not work in an IDE.
  • It is very frustrating that this feature is not working (F2,Ctrl+Shift+F12). My uVision(5.33.0.0) often crashes after pressing F2. Editor is very weak point of uVision and I guess there is no chance it will improve. https://www.scintilla.org/ is used according to 'About uVIsion'
  • The generation of browse information in µVision is different in the case of using Arm compiler v5.x or Arm compiler v6.x.
    If you use Arm compiler v5.x, the browse info is generated when you build your project by the same arm compiler v5.x toolchain. That's also the main reason why enabling "Options for Target - Output - Browse information" option in this case will slow down the build time.
    If you use Arm compiler v6.x, the browse info is generated in the background of µVision dynamically using a different compiler toolchain other than arm compiler v6.x. In some cases, this specific compiler cannot generate the browse info for a certain type of code for some reason, or in the worst case can lead to the crash of the browse info generation compiler/module. That's why to find the root cause of such an issue, a source code module or at least a code snippet is necessary for Arm to reproduce the issue
  • I was wrong in linking Editor with F2. Thank you for the detailed explanation.
    You confirmed my findings. I noticed that input from keyboard is often ignored for few seconds when in editor. I looked what uVision is doing and there is a clang thread often taking as much as 10% of the CPU - without compiling code or using editor. Is it possible to turn off that dynamic syntax checking/browse info generation ? Would be great to have this option.
  • You can turn off the generation of browse info via the option "Options for Target - Output - Browse Information" in uVision
    You can also turn off the dynamic syntax checking via "Configuration - Text Completion - Dynamic Syntax Checking" in uVision
  • I don't know which version of uVision had/has this, but I learned a long time ago that changing the "Name of Executable" caused a problem with this. For instance, don't add an extension to that filename.
  • At the time I reported the issue, the "effect" had a 50% probability. In the meantime, our project has grown and the search almost doesn't work at all. Sometimes you see what you're looking for a few lines up, but the search isn't able to find it. Unfortunately I was not allowed to provide the code, so I hope that others have the same problem and that it will be solved soon. Since I personally need this functionality very often, I find working with uvision extremely uncomfortable and can only advise against using it.
  • There might be some correlation with the project size. It crossed my mind. Difficult to judge. We have no clue what is priority for them. I would guess it is well known issue but there is just not enough resources to sort it out. It is a trade off. You might expect this with free version but when you spend several thousand you migh say it is shocking
    Depressing ? Definitelly. Is it depressing enough I spend time to integrate toolchain with other robust IDE ? No.
  • have you tried the latest MDK v5.37? Is there improvement with your project using the latest MDK v5.37?
  • I run this tool
    github.com/.../cloc
    on my project and got  >100k line of code.
    No idea how this would be described as in relation to what uVision is designed to handle. Big/middle/small sized project ?
    Is not there some log where the browse info generator outputs its state and reason of failure ? If not, could you add this to next release ?
    It is confusing because my program links so all neccesary information is clearly available to the linker (this is how v5 works as you explained). But with v6 browse info must be extracted without linking. Interesting.
  • What toolchain version do you use ? v5.x or v6.x
  • (I used compiler v6.16 before ... now it is 6.18)
    Today I updated to version 5.37, recommended by Cheng Tang
       I still can't believe it, but it seems the problem has been solved.
    So far all searches have worked (apart from the fact that the cursor is sometimes not positioned correctly). That looks really good, I'll get back to here if one search doesn't work...
