Hi.
I use keil to compile a simple program, the program is as follows.
#include "stm32f10x.h"
int main() { while(1) { } }
Prompt the following error.
ArmClang: error: Failed to check out a license.Keil Licensing error: Support expired. New Product Serial Number (PSN) requiredArmClang: note: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at: www.keil.com/.../license_management.htm If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_PRODUCT_DEF: unset - ARM_PRODUCT_PATH: unset - ARM_TOOL_VARIANT: unset - Product location: D:\keil\ARM\sw\mappings - Toolchain location: D:\keil\ARM\ARMCLANG\Bin - Selected tool variant: mdk_stdArmClang: note: - Checkout feature: LIC0=KA...-.....-..... - Feature version: 5.0202103 - Keil error code: 1Product: MDK Plus 5.35Component: ARM Compiler 6.16Tool: armclang [5dfeb700]
Hope you can help me. Thanks.
LICENSE
Obviously, you have installed a product version of Keil MDK that is not supported by your expired contract.
- I recommend contacting your local distributor to order an upgrade:
http://www.keil.com/distis/
Latest release at the moment: https://www.keil.com/update/relnotes/MDK535.htm
- Another solution - register a supported Keil MDK version, offered at:
https://www.keil.com/download/product/
