Issues listed below for imxrt1024 controller working with Keil v5.34 MDK , compiler v6(default)
1.Need Debug parameters for iMXRT1024 controller (Dailog parameters like (CPU.DLL & Dailog.DLL )
2.Simulation of imxrt1024 controller (Peripherals not updated their register )
Example: I assign a GPIO1 pin 24 as output . So i need to toggle and set and clear but it only shows GPIO direction updated
GPIO1->DR_TOGGLE & GPIO1->DR_SET & GPIO1->DR_CLEAR not working
3.Logic Analyzer of GPIO pins not assign . Can u please syntax of particular GPIO port pins assigned in logic analyzer
I need parameters this for IMXRT1024 controller
With almost 9000 devices supported, Simulation is limited with Keil MDK.
In general, refer to:
Simulation of Cortex-M Devices
https://developer.arm.com/documentation/ka002225/latest
Also, for the imxrt1024, there are prepared examples projects provided as a reference by the Pack Installer
Thanks for reply to me but answers are not suitable to me, Because what you should given information that was not present for my problem. please check once .....
Yes, sample projects, i seen and also tested but simulation was not working like seen above example for gpio..
And also parametrs list not present for Imxrt1024 ..first please verify i need cortex m7 (imxrt1024 parameters)
