have written this ARM assembly code. It is supposed to put the Fibonacci sequence numbers in R4 register. I'm trying to implement this C code in assembly:
int fibbonacci(int n) { if(n == 0) return 0; else if(n == 1) return 1; else return (fibbonacci(n-1) + fibbonacci(n-2)); }
This is the assembly code I have written:
AREA |.text|, CODE, READONLY EXPORT Fib Fib ;R0(n) - store the first n numbers in the Fibonacci sequence ;R1 - address of the first element in the array to store the Fibonacci sequence MOV R4, #0 MOV R5, #0 MOV R6, #1 FiboR CMP R0, #1 PUSHEQ {R5, R6, LR} BEQ Return SUBS R0, R0, #1 BL FiboR ADD R4, R2, R3 PUSH {R4, R2, LR} Return POP {R2, R3, PC} ALIGN END
It is not behaving exactly like that posted C code so far because I need to keep working on it and make it return to main after it prints the first 5 numbers. However for now I need to fix something.
When my code reaches this line:
PUSH {R4, R2, LR}
It's supposed to push values R4, R2 and LR on the stack which at that moment are: 1, 0, LR. Then the code goes down into the 'Return' subroutine in which I'm doing this:
POP {R2, R3, PC}
So at this moment R2 should be loaded with value 1, R3 with value 0 and PC with value of LR so I return to this line:
ADD R4, R2, R3
The code does return to the ADD line however the value of R2 is not loaded with the value 1 as I expected it to. My code stays here in an infinite loop and I keep pushing {1, 0, LR} on the stack but when I try to pop these values into R2, R3 and PC apparently they are not getting popped as I would expect them to at least value 1 does not go into R2 and R2 keeps it's value of 0 forever.
Can you please help me what am I missing here? Thank you for reading!
