Hello all,
Can anyone please explain this LPC2129 code in detail. It uses RTC to display the current time on UART0. The code works alright just needs an in-depth explanation. The code is attached below.
#include<LPC21xx.h>
void rtc_init(void);
void Uart_Init(void)
U0LCR= 0x9B; //8 bits data, 1 stop bit, even parity /* line control registor */
U0DLL= 0x62; //9600 baud rate /* baud rate registor */
U0DLM= 0x00; /* baud rate registor */
U0LCR= 0x1B; //disable the access of DLL DLM so that we can access U0THR
void Uart_Data(unsigned char data)
U0THR = data;
while((U0LSR & 0X20)!= 0X20);
void Uart_String(unsigned char *dat)
while(*dat!='\0')
Uart_Data(*dat);
dat++;
void Port_Initial(void)
PINSEL0 = 0x00000005;
int main()
Port_Initial();
Uart_Init();
Uart_String("18070123123\n");
//Uart_Data('\n');
Uart_String("Tanay Tripathi");
PREINT=0x1C7;
PREFRAC=0xE1C0;
AMR=0xFF; //mask all bits ie. no alarm
rtc_init(); //initialize all seconds,minute and hour values
CCR=0x01; //timer started
while(1) //to keep alive so as to monitor the clock
Uart_Data(HOUR/10+'0');
Uart_Data(HOUR%10+'0');
Uart_Data(':');
Uart_Data(MIN/10+'0');
Uart_Data(MIN%10+'0');
Uart_Data(SEC/10+'0');
Uart_Data(SEC%10+'0');
Uart_String("\n");
void rtc_init()
SEC=20; //Initialized seconds
MIN=00; //Initialized minutes
HOUR=12;//Initialized hour
For questions about the specific peripherals in a particular chip, you need to ask the chip manufacturer - NXP, in this case:
https://community.arm.com/developer/tools-software/tools/f/keil-forum/43684/lpc2148-timer0-not-working-as-expected/158950#158950
Thanks, I give it a go to figure it out.
slope game
