hello
im trying to download stm32f429 discovery board packs but i had this error
how can i solve this please thanks in advanced
Cannot download file www.keil.com/.../Keil.STM32F4xx_DFP.2.15.0.pack: Server or proxy not found
the proxy setting of Pack Installer is derived/inherited from the internet proxy setting in your windows control panel. You may check your windows proxy settings if they are correct.
As an alternative, you can manually download software packs from http://www.keil.com/dd2/pack/
what shall i do after downloading it where should i coppy and paste it or how to update the new directory ?
After you manually download the packs from the link above, just double click on it. The Pack Installer will unzip it and install it into your default Pack installation folder you defined when you installed your MDK
many thanks
