Hello, at the begining sorry for my English. I have a problem with keil interface. I reseted my computer and i installed keil uVision 5.29 back.
As you can see the codes are not colored as before. I have no problem with compiling also i can upload my codes to my board (STM32vldiscovery) and it works.
But i can not focus coding in this situation. If you know about it pls let me know. Thank you!
You need to delete the file C:\Keil\UV4\global.prop
Removing this file will force a new creation with default settings, as stored in global.prop.def
Thank you for your reply. I did it and it worked. Thank you so much.
