I have been making some clocks configuration changes in C code. I verified the register values using the debugger. I have made below code changes to check the clock frequencies using oscilloscope . ie, MCO to PA8
After making the below code changes, ULINK2 is unable to connect with the device. The moment after I click "Load" I get error as "No Cortex-M Device found in JTAG chain" . It was working fine before I load this code. The uVersion I use is 5.33.
I did try setting the debug settings,
1. Connect: with Pre-reset
2. Enabled Reset after Connect
3. Rest: HW RESET
4. Enabled Stop after Reset
//Set the MCO to SysCLKpRcc->CFGR |= RCC_CFGR_MCOSEL_0;
// Enable alternate function for GPIOA8GPIOA->MODER |= GPIO_MODER_MODE8_1;
// Configure GPIOA8 to very high speedGPIOA->OSPEEDR |= (GPIO_OSPEEDR_OSPEED8_1| GPIO_OSPEEDR_OSPEED8_0);
//Alternate function for portA-8GPIOA->AFR[1] |= GPIO_AFRH_AFSEL8_3;
Can someone help me resolving the issue?
PA8 isn't used by the debug interface - is it?
