Hello Everyone,
Several errors are being showned while designing this program. Please help me out. Hoping for a positive co-operation.
Following is this programme code :
#include<reg51.h>void lcdcmd(unsigned char);void lcddata(unsigned char);void MSDelay(unsigned int);void disp_num(float num);int get_num(char ch);void lcdinit();char scan_key(void);unsigned char s[17]={"ENTER GENDER = "};unsigned char s1[12]={"ENTER AGE = "};unsigned char s2[15]={"ENTER WEIGHT = "};unsigned char s3[15]={"ENTER HEIGHT = "};unsigned char s4[12]={"PARAMETER = "};sfr ldata = 0xA0;sbit rs = P3^7;sbit rw = P3^5;sbit en = P3^6;sbit r0=P1^0;sbit r1=P1^1;sbit r2=P1^2;sbit r3=P1^3;sbit c0=P1^4;sbit c1=P1^5;sbit c2=P1^6;sbit c3=P1^7;
void lcdinit(){ MSDelay(15000);lcdcmd(0x30);MSDelay(4500);lcdcmd(0x30);MSDelay(300);lcdcmd(0x30);MSDelay(600); lcdcmd(0x38); lcdcmd(0x0F); lcdcmd(0x01); lcdcmd(0x06); lcdcmd(0x80);}
int main (void) { while(1){ unsigned int k=0,m=0,n=0,l=0,p=0;double a1,w2,h3,e,b,q; char key,key1;unsigned char ch2,ch1; lcdinit();
while(s[k]!='\0'){lcddata(s[k]);k++;}ch1=scan_key(); lcddata(ch1);lcdcmd(0x01);
while(s1[m]!='\0'){lcddata(s1[m]);m++;}key=scan_key();a1=get_num(key);lcddata(key);lcdcmd(0x01);
while(s2[n]!='\0'){lcddata(s2[n]);n++;}key=scan_key();w2=get_num(key);lcddata(key);lcdcmd(0x01);
while(s3[l]!='\0'){lcddata(s3[l]);l++;}key1=scan_key();h3=get_num(key1);lcddata(key1); lcdcmd(0x01);
while(s4[p]!='\0'){lcddata(s4[p]);p++;}ch2=scan_key(); lcddata(ch2);lcdcmd(0x01);switch(ch2)
{case '+':disp_num(w2/h3*h3);break;
case '-': e = 10*w2+6.25*h3-5*a1+5disp_num(e);break;
case '*': b = 1.20*(w2/h3*h3)+0.23*a1-16.2disp_num(b);break;
case '/': q = 0.407*w2+0.267*h3-19.2disp_num(q);break;}return 0;}}void lcdcmd(unsigned char value) { ldata = value; rs = 0; rw = 0; en = 1; MSDelay(50); en = 0;MSDelay(50); }void lcddata(unsigned char value) { ldata = value; rs = 1; rw = 0; en = 1; MSDelay(50); en = 0; MSDelay(50); }void MSDelay(unsigned int itime) { unsigned int i, j; for(i=0;i< itime;i++) for(j=0;j<5;j++); }char scan_key(){unsigned char c;c='s';while(!(c=='0' && c=='1' && c=='2' && c=='3' && c=='4' && c=='5' && c=='6' && c=='7' && c=='8' && c=='9' && c=='+' && c=='-' && c=='#' && c=='$' && c=='*' && c=='/' )){r0=0;r1=1;r2=1;r3=1;if(c0==0 && r0==0 ){lcddata('1');MSDelay(100000);return c='1';} if(c1==0 && r0==0){ lcddata('2');MSDelay(100000);return c= '2';}if(c2==0 && r0==0){ lcddata('3');MSDelay(100000);return c= '3';}if(c3==0 && r0==0){ lcddata('4');MSDelay(100000);return c= '4';} r0=1;r1=0;r2=1;r3=1;
if(c0==0 && r1==0){ lcddata('5');MSDelay(100000);return c= '5';} if(c1==0 && r1==0){ lcddata('6');MSDelay(100000);return c= '6';}if(c2==0 && r1==0){ lcddata('7');MSDelay(100000);return c= '7';}if(c3==0 && r1==0){ lcddata('8');MSDelay(100000);return c= '8';}
r0=1;r1=1;r2=0;r3=1;
if(c0==0 && r2==0){ lcddata('9');MSDelay(100000);return c= '9';} if(c1==0 && r2==0){ lcddata('0');MSDelay(100000);return c= '0';}if(c2==0 && r2==0){ lcddata('+');MSDelay(100000);return c= '+';}if(c3==0 && r2==0){ lcddata('-');MSDelay(100000);return c= '-';}
r0=1;r1=1;r2=1;r3=0;
if(c0==0 && r3==0){ lcddata('*');MSDelay(100000);return c= '*';} if(c1==0 && r3==0){ lcddata('/');MSDelay(100000);return c= '/';}if(c2==0 && r3==0){ lcddata('^');MSDelay(100000);return c= '^';}if(c3==0 && r3==0){ lcddata('#');MSDelay(100000);return c= '#';}}return 0;}
int get_num(char ch) //convert char into int{switch(ch){case '0': return 0; break;case '1': return 1; break;case '2': return 2; break;case '3': return 3; break;case '4': return 4; break;case '5': return 5; break;case '6': return 6; break;case '7': return 7; break;case '8': return 8; break;case '9': return 9; break;}return 0;}
void disp_num(double num) //displays number on LCD{unsigned char UnitDigit = 0; //It will contain unit digit of numbunsigned char TenthDigit = 0; //It will contain 10th position digit of numbunsigned char decimal = 0;int j;int numb;j=(int)(num*10);numb=(int)num;if(numb<0){numb = -1*numb; // Make number positivelcddata('-'); // Display a negative sign on LCD}
TenthDigit = (numb/10); // Findout Tenth Digit
if( TenthDigit != 0) // If it is zero, then don't displaylcddata(TenthDigit+0x30); // Make Char of TenthDigit and then display it on LCD
UnitDigit = numb - TenthDigit*10;
lcddata(UnitDigit+0x30); // Make Char of UnitDigit and then display it on LCDlcddata('.');decimal=(j%10)+0x30;lcddata(decimal);MSDelay(2000000);}
>>Several errors are being shown while designing this program.
Start with the first one, and work your way through them. Perhaps try to get simpler sub-portions working first, ie screen or keyboard.
"We are very new to this"
Very new to what, exactly: do you have ay experience with any other microcontroller(s)? do you have any experience with programming in general?
As Westonsupermare Pier says, the key to solving big/complicated problems is to break them down into smaller sections until you can solve them:
www.avrfreaks.net/.../3116326
