Dear All,
I suffer a problem. I am starting debug mode with my FPGA which includes ARM-M0.
I already set LOAD %L INCREMENTAL in my Ram.ini, but it is fail during staring debug.
The error message is as below
A). I don't understand why to access memory is fail ? But if
1.
Step 1: Press download icon to download SW code to code memory
Step 2: To start debug is OK
2.
Step 1: Enable Utility > Update Target before Debugging
Step 2: build code
Step 3: To start debug is also OK.
According to the experiments from 1 and 2, I should download code before staring debug, but I don't understand why it is fail for LOAD %L INCREMENTAL in my Ram.ini. The error message is
*** error 122: AGDI: memory read failed (0xFFFFFFFE) Cannot access Memory (@ 0xfffffffe, Read, Acc Size: 2 Byte)
B). What is address 0xFFFFFFFE for M0?
Thanks for you help.
BR,
Eddie
for B), check the memory map of Cortex-M0 here developer.arm.com/.../memory-model
