Hi! I have STM32H745 Nucleo and i want to transfer data from ADC via DMA.
1. At first i write code for ADC with out DMA (ADC3, PF10 in) and it work excellent. I get positive knovlege.
2. At second step i tried to use DMA (DMA1 stream 1, PF10, ADC3), but code don't work.
It is code with DMA:
void ADC3_DMA_Config(void)
GPIO_InitTypeDef GPIO_InitStruct;
static DMA_HandleTypeDef DmaHandle;
/* ADC handler declaration */
ADC_HandleTypeDef AdcHandle_singl;
ADC_ChannelConfTypeDef sConfig;
__HAL_RCC_GPIOF_CLK_ENABLE() ;
__HAL_RCC_ADC3_CLK_ENABLE() ;
__HAL_RCC_ADC_CONFIG(RCC_ADCCLKSOURCE_CLKP);
__HAL_RCC_DMA1_CLK_ENABLE();
GPIO_InitStruct.Pin = GPIO_PIN_10 ;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
DmaHandle.Instance = DMA1_Stream1;
DmaHandle.Init.Request = DMA_REQUEST_ADC3;
DmaHandle.Init.Direction = DMA_PERIPH_TO_MEMORY;
DmaHandle.Init.PeriphInc = DMA_PINC_DISABLE;
// DMA1_Stream1->PAR = (uint32_t)&ADC3->DR;
// DMA1_Stream1->M0AR = (uint32_t)&ADC1ConvertedValue;
DmaHandle.Init.MemInc = DMA_MINC_ENABLE;
DmaHandle.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
DmaHandle.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
DmaHandle.Init.Mode = DMA_CIRCULAR;
DmaHandle.Init.Priority = DMA_PRIORITY_HIGH;
HAL_DMA_DeInit(&DmaHandle);
HAL_DMA_Init(&DmaHandle);
DMAMUX1_Channel1->CCR|= 115U;; //stream 1 29 ????
//DMAMUX1_Channel1->CCR = (115u << DMAMUX_CxCR_DMAREQ_ID_Pos);
DMA1_Stream1->CR |= DMA_SxCR_EN;
AdcHandle_singl.Instance = ADC3;
AdcHandle_singl.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV2;
AdcHandle_singl.Init.Resolution = ADC_RESOLUTION_16B;
AdcHandle_singl.Init.ScanConvMode = DISABLE;
AdcHandle_singl.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
AdcHandle_singl.Init.LowPowerAutoWait = DISABLE;
AdcHandle_singl.Init.ContinuousConvMode = ENABLE ;
AdcHandle_singl.Init.NbrOfConversion = 1;
AdcHandle_singl.Init.DiscontinuousConvMode = DISABLE;
AdcHandle_singl.Init.NbrOfDiscConversion = 1;
AdcHandle_singl.Init.ExternalTrigConv = ADC_SOFTWARE_START; ;
AdcHandle_singl.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
AdcHandle_singl.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR;
AdcHandle_singl.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
AdcHandle_singl.Init.OversamplingMode = DISABLE;
if (HAL_ADC_Init(&AdcHandle_singl) != HAL_OK)
; //Error_Handler();
/* ### - 2 - Start calibration ############################################ */
if (HAL_ADCEx_Calibration_Start(&AdcHandle_singl, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED) != HAL_OK)
sConfig.Channel = ADC_CHANNEL_6; //ADC3_CHANNELa; /* Sampled channel number */
sConfig.Rank = ADC_REGULAR_RANK_1; /* Rank of sampled channel number ADCx_CHANNEL */
sConfig.SamplingTime = ADC_SAMPLETIME_8CYCLES_5; /* Minimum sampling time */
sConfig.SingleDiff = ADC_SINGLE_ENDED; /* Single-ended input channel */
sConfig.OffsetNumber = ADC_OFFSET_NONE; /* No offset subtraction */
sConfig.Offset = 0; /* Parameter discarded because offset correction is disabled */
if (HAL_ADC_ConfigChannel(&AdcHandle_singl, &sConfig) != HAL_OK)
/* ### - 4 - Start conversion in DMA mode ################################# */
if (HAL_ADC_Start_DMA(&AdcHandle_singl,
(uint32_t *)aADCxConvertedData,
ADC_CONVERTED_DATA_BUFFER_SIZE
) != HAL_OK)
