I need to use ARM compiler V5.06 update 7 not only V6.15 in a project of S32K144 for some backward compatibility issues.
Please, recognize the following 2 pictures:
This is when I use compiler V6:
This is when I use V5:
The startup code is available in V6 only. Does this mean that I can not compile S32K144 codes with V5 or at least it will not work ?
Actually I tried to use the same startup code of V6 while compiling with V5 and it did compile with 0 errors, 0 warnings but the code never runs on the target and can not debug it (while using V5) to know the root cause.
What could be the root cause of such a problem and why there is no available startup code when choosing V5 in the "Options for Target" ?
It is a general issue of some NXP packs made and released by NXP:
www.keil.com/.../4202.htm
