When the *pointer point to an array, as follow:
int *pointer = malloc(sizeof(int) * 10);
How can I watch the array in the debug WATCH windows?
In Visual studio , we can use "pointer, 10" to watch the array easily. Can keil do like this??
Hi Forevy,
Yes, you can add variables to a watch window in KEIL to view the value. You have to select the variable when you are debug mode, and then "add to watch 1". You will see a window with the value of your variable.
Here you have more information: www.keil.com/.../uv4_db_dbg_watchwin.htm
BR.
Thank you for answering, but you don't understand my question!
