The screen is like this, I can't see the right side. Does anyone know the solution to this problem?
The screen is like this, I can't see the right side. Does anyone know the solution to this problem? pls help me
You should check the windows OS fonts and screen scaling settings, as described here www.keil.com/.../3974.htm
it is not working
Does our Knowledgebase Article help?
µVISION: Reset View To Customer Defaults
www.keil.com/.../3890.htm
