I have this little assem;++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ ; SI PULSAMOS P1.0 TENEMOS UNA ONDA CUADRADA ; CONTROLADA POR EL FLAG DE SU TMR DE <6 HZ A 26 kHz> ; LA RUTINA LIMPIA LA BANDERA TF1 ;++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ $NOMOD51 $INCLUDE (C:\C51\INC\Atmel\AT89LP214.h) USING 00 ORG 00H MOV IE,10001111B // IE (EA+TMR0+) MOV TCON,01011010B // TCON - START/STOP TMRs MOV TCONB,11000000B // TCONB | PSC | PWM 091H MOV TMOD,00000000B // TMOD | (13 bits) MOV CLKREG,00000000B // CLKREG | TPS / CDV MOV P3M1,#00000000B // P3M1 MOV P3M0,#00001111B // P3M0 Entradas MOV P1M1,#00000000B // P1M1 MOV P1M0,#00000011B // P1M0 CUADRADA: SETB P1.6 ACALL TIEMPO CLR P1.6 ACALL TIEMPO DJNZ 0FFH,CUADRADA ORG 03H CUADRADA1: SETB P1.4 ACALL TIEMPO CLR P1.4 ACALL TIEMPO PULSA1: JNB P1.1,PULSA1 // Captura pulsación ;SJMP CUADRADA1 DJNZ 0FFH,CUADRADA1 RETI TIEMPO: MOV TL1,#000H MOV TH1,TL1 SETB TR1 AQUI1: JNB TF1,AQUI1 // Rearma FLAG TMR_0 CLR TF1 CLR TR1 RET ENDbler program and it won't start the program from the IRQ call, I check everything and I don't see the error, you can take a look at it. Thank you.
