Hello i am including rcc_config.h file which has the following functions as shown in the attached code.
But Keil gives me the follwing errors
what should i do with those warnings if i want to use thos functions in the H file inside main.c?
Thanks.
void SysClockConfig (void) { /****>>>>>>> STEPS FOLLOWED <<<<<<<<***** 1. ENABLE HSE and wait for the HSE to become Ready 2. Set the POWER ENABLE CLOCK and VOLTAGE REGULATOR 3. Configure the FLASH PREFETCH and the LATENCY Related Settings 4. Configure the PRESCALARS HCLK, PCLK1, PCLK2 5. Configure the MAIN PLL 6. Enable the PLL and wait for it to become ready 7. Select the Clock Source and wait for it to be set ********************/ #define PLL_M 4 #define PLL_N 180 #define PLL_P 0 // PLLP = 2 // 1. ENABLE HSE and wait for the HSE to become Ready RCC->CR |= RCC_CR_HSEON; // RCC->CR |= 1<<16; while (!(RCC->CR & RCC_CR_HSERDY)); // while (!(RCC->CR & (1<<17))); // 2. Set the POWER ENABLE CLOCK and VOLTAGE REGULATOR RCC->APB1ENR |= RCC_APB1ENR_PWREN; // RCC->APB1ENR |= 1<<28; PWR->CR |= PWR_CR_VOS; // PWR->CR |= 3<<14; // 3. Configure the FLASH PREFETCH and the LATENCY Related Settings FLASH->ACR = FLASH_ACR_ICEN | FLASH_ACR_DCEN | FLASH_ACR_PRFTEN | FLASH_ACR_LATENCY_5WS; // FLASH->ACR = (1<<8) | (1<<9)| (1<<10)| (5<<0); // 4. Configure the PRESCALARS HCLK, PCLK1, PCLK2 // AHB PR RCC->CFGR |= RCC_CFGR_HPRE_DIV1; // RCC->CFGR &= ~(1<<4); // APB1 PR RCC->CFGR |= RCC_CFGR_PPRE1_DIV4; // RCC->CFGR |= (5<<10); // APB2 PR RCC->CFGR |= RCC_CFGR_PPRE2_DIV2; // RCC->CFGR |= (4<<13); // 5. Configure the MAIN PLL RCC->PLLCFGR = (PLL_M <<0) | (PLL_N << 6) | (PLL_P <<16) | (RCC_PLLCFGR_PLLSRC_HSE); // (1<<22); // 6. Enable the PLL and wait for it to become ready RCC->CR |= RCC_CR_PLLON; // RCC->CR |= (1<<24); while (!(RCC->CR & RCC_CR_PLLRDY)); // while (!(RCC->CR & (1<<25))); // 7. Select the Clock Source and wait for it to be set RCC->CFGR |= RCC_CFGR_SW_PLL; // RCC->CFGR |= (2<<0); while ((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_PLL); // while (!(RCC->CFGR & (2<<2))); } void GPIO_Config (void) { /**** STEPS FOLLOWED ***** 1. Enable the GPIO CLOCK 2. Set the Pin as OUTPUT 3. Configure the OUTPUT MODE *************/ // 1. Enable the GPIO CLOCK //RCC->AHB1ENR |= (1<<0); RCC->AHB1ENR|=RCC_AHB1ENR_GPIODEN; // 2. Set the Pin as OUTPUT //GPIOA->MODER |= (1<<10); // pin PA5(bits 11:10) as Output (01) GPIOD->MODER &=~(0x1UL<<31U); GPIOD->MODER |=(0x1UL<<30U); // 3. Configure the OUTPUT MODE GPIOD->OTYPER = 0; GPIOD->OSPEEDR = 0; } void delay (volatile uint32_t time) { while (time--); }
Build started: Project: less02_NO_HALL*** Using Compiler 'V6.15', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'Build target 'Target 1'main.c(1): warning: In file included from..../rcc_config.h(43): warning: no previous prototype for function 'SysClockConfig' [-Wmissing-prototypes]void SysClockConfig (void) ^./rcc_config.h(43): note: declare 'static' if the function is not intended to be used outside of this translation unitvoid SysClockConfig (void)^static ./rcc_config.h(98): warning: no previous prototype for function 'GPIO_Config' [-Wmissing-prototypes]void GPIO_Config (void) ^./rcc_config.h(98): note: declare 'static' if the function is not intended to be used outside of this translation unitvoid GPIO_Config (void)^static ./rcc_config.h(122): warning: no newline at end of file [-Wnewline-eof]} ^./rcc_config.h(118): warning: no previous prototype for function 'delay' [-Wmissing-prototypes]void delay (volatile uint32_t time) ^./rcc_config.h(118): note: declare 'static' if the function is not intended to be used outside of this translation unitvoid delay (volatile uint32_t time)^static 4 warnings generated.compiling main.c...linking...Program Size: Code=376 RO-data=408 RW-data=0 ZI-data=1632 ".\Objects\less02_NO_HALL.axf" - 0 Error(s), 4 Warning(s).Build Time Elapsed: 00:00:01
It is required:
- ...to know the Keil product and version, as well as the target and Pack in use
- ...to see the context of your rcc_config.h implementation
Beside, I recommend to see:
"Automatic function inlining and static functions"
www.keil.com/support/man/docs/armcc/armcc_chr1359124226591.htm
as part of the Compiler User Guide.
Hello ,the content of RCC_config file is the attached code in the first code.
the vesrion is 5.33 as shown bellow.
What could be done to solve those warnings?
rocko874 said:no previous prototype for function 'SysClockConfig'
So provide a prototype, then.
How to make sure i could use those function from the *.h file?
presumably, they are declared in some other header file?
Start with a working example to see how it all hangs together...
Links to a load of ST and Keil training materials:
community.arm.com/.../109675
