Hello MrChips I have written the following code for microsecond delay ,i just use delay(1000) to have 1milisecond delay.I cant see the dinammic of the the delay.my APB1 clock is 21Mhz ,ARR=21 makes the counter to overflow every 1MHz and call the TIM4_IRQHandler function which will increase myticks by 1.but how in parralel the delay function will check if myticks<us, as i see it ,we will be stuck on the delay "while"how in paralel the TIM4_IRQHandler will run timer overflow?Can i see it in KEIL debugging? because debugging is not time based,its sequential.Thanks.
void delay(int us) { TIM4->CR1|=TIM_CR1_CEN; myticks=0; while(myticks<us); TIM4->CR1&=~TIM_CR1_CEN; } void TIM4_IRQHandler(void) { myticks++; TIM4->SR&=~TIM_SR_UIF; } int main(void) { RCC->APB1ENR|=RCC_APB1ENR_TIM4EN; TIM4->PSC=0; TIM4->ARR=21; TIM4->CR1|=TIM_CR1_URS; TIM4->DIER|=TIM_DIER_UIE; TIM4->EGR=TIM_EGR_UG; NVIC_EnableIRQ(TIM4_IRQn);
