I'm using an US keyboard for coding witg KEIL uVision V4.24.00.0 and trying to get the right ALT modifier key for Umlauts working.
This does work with most other applications.
But in uVision, all it does, is to open the window menus, as does the left ALT key.
Is there any way to change this behaviour?
Best Regards,
Marc
Are you just asking about how to type umlauts into your source code, or how to have your target system display umlauts in its runtime output?
I"m asking about how to type Umlauts into the sourcecode.
Sorry about not to be specific.
The standard Windows Character Map works for me:
EDIT
Note that the Character Map tells you the codes:
I went with using EURKEY keyboard layout.
Now everything works as expected.
Thank you.
