Hello,I have tried to create a systick delay using systick interrupt as shown in the code bellow.
But It shows me those warnings shown bellow,and nothing happens on my STM32 shown bellow.Where did i go wrong?Thanks.
#include "stm32f407xx.h" volatile uint16_t delay_count=0; void SysTick_Handler(void)//called every 1ms { if (delay_count>0) { delay_count--; } } void delay_ms(uint16_t delay_temp) { delay_count=delay_temp; while(delay_count){} } int main() { RCC->AHB1ENR|=(1uL<<3); //set thirdbit //GPIOD->MODER&=~(1uL<<31);//reset 0 on 31 01 to gpio_moder 31,30 bits in register //GPIOD->MODER|=(1uL<<30);//set 1 on 30 output mode for pin 15 port D GPIOD->MODER=0x55000000; SysTick_Config(SystemCoreClock/1000);//1 ms interrupt GPIOD->OTYPER=0; //all register is push pull GPIOD->OSPEEDR=0;//speed low //GPIOD->ODR|=(1<<15); //Sets pin 15 while(1) { GPIOD->BSRR=(1uL<<15); delay_ms(500); GPIOD->BSRR=(1uL<<(15+16)); delay_ms(500); } }
Build target 'Target 1'bob.c(3): warning: no previous extern declaration for non-static variable 'delay_count' [-Wmissing-variable-declarations]volatile uint16_t delay_count=0; ^bob.c(3): note: declare 'static' if the variable is not intended to be used outside of this translation unitvolatile uint16_t delay_count=0; ^bob.c(4): warning: no previous prototype for function 'SysTick_Handler' [-Wmissing-prototypes]void SysTick_Handler(void)//called every 1ms ^bob.c(4): note: declare 'static' if the function is not intended to be used outside of this translation unitvoid SysTick_Handler(void)//called every 1ms^static bob.c(11): warning: no previous prototype for function 'delay_ms' [-Wmissing-prototypes]void delay_ms(uint16_t delay_temp) ^bob.c(11): note: declare 'static' if the function is not intended to be used outside of this translation unitvoid delay_ms(uint16_t delay_temp)^static 3 warnings generated.compiling bob.c...linking...Program Size: Code=600 RO-data=424 RW-data=4 ZI-data=1640 ".\Objects\try1.axf" - 0 Error(s), 3 Warning(s).Build Time Elapsed: 00:00:00Load "C:\\Keil_v5\\less01\\Objects\\try1.axf" Erase Done.Programming Done.Verify OK.Application running ...Flash Load finished at 13:12:31Load "C:\\Keil_v5\\less01\\Objects\\try1.axf" Erase Done.Programming Done.Verify OK.Application running ...Flash Load finished at 13:12:46
