;++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ ; SI PULSAMOS P1.0 TENEMOS UNA ONDA CUADRADA ; CONTROLADA POR EL FLAG DE SU TMR DE <6 HZ A 26 kHz> ; LA RUTINA LIMPIA LA BANDERA TF1 ;++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ ORG 00H USING 00H MOV IE,10001111B // IE (EA+TMR0+) MOV 088H,01011111B // TCON - START/STOP TMRs MOV 091H,11111000B // TCONB | PSC | PWM MOV 089H,00001000B // TMOD | (13 bits) MOV 08FH,00000000B // CLKREG | TPS / CDV MOV 0BFH,#00000000B // P4M1 MOV 0BEH,#00000000B // P4M0 MOV 0C7H,#00000000B // P3M1 MOV 0C6H,#00000000B // P3M0 MOV 0C5H,#00000000B // P2M1 MOV 0C4H,#00000000B // P2M0 MOV 0C3H,#00000000B // P1M1 MOV 0C2H,#00000001B // P1M0 CUADRADA: SETB P1.6 ACALL TIEMPO CLR P1.6 ACALL TIEMPO PULSA: JB P1.0,PULSA // Captura pulsación SJMP CUADRADA TIEMPO: MOV TL1,#000H MOV TH1,TL1 SETB TR1 AQUI1: JNB TF1,AQUI1 // Rearma FLAG TMR_0 CLR TF1 CLR TR1 RET END
Can someone tell me why two routines cannot be executed in closed loop? I already introduced the DJNZ instruction for not using an AJMP, which is a closed loop tending to infinity and maybe the processor core could not get out of the loop.
Well, now I understand the limitation of simultaneous routines, it certainly does not make sense to determine a routine to attend another, except when using IRQs, thanks for your answer.
