I am developing a system wich consists in a vary of functionalities, and I have to implement an HTTP server.
I call tick_timer() in the SysTick handler at 100ms, and in my while(1) I have the main_TcpNet() call.
Ok then I have the Timer 0 interrupting at a given frequ(10Hz) in which I start the bust mode of the ADC and then in the ADC handler I stop it, so I can control the sampling freq.
The problem is that if I have the ADC working, the HTTP server does not responds to my web browser, but if I comment the start line of the ADC in the Timer 0( so the ADC does not work) the server works perfect.
I am developing it on an LPC1768 board, the pins used for the ADC are P0.24 and P0.25, so it is not a pin problem, the interrupts work at the given freq each...
This is the board www.hotmcu.com/lpc1768minidk2-development-board-p-55.html
