I want to use the CMSIS-DSP library for the STM32G431 to implement a fixed point FIR. In the Keil RTE I selected CMSIS-DSP and installed the Libraries. I haven't yet added the FIR code to my project but I did add the include "arm_math.h".
In the Keil project, under CMSIS it shows the path to "arm_cortex_M4lf_math.lib (DSP)" and I can see an entire CMSIS 5.7.0 is installed along with DSP.
When I compile my program I get the error shown below:
1) What is the cause of this compile error?
compiling phase_det.c... ../Drivers/CMSIS/Include/core_cm4.h(81): error: #35: #error directive: "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" ..\Src\phase_det.c: 0 warnings, 1 error
