Flash Programming Algorithm is not in list
I built a Flash Programming Algorithm (FLM) according to Flash Programming Algorithm. Then I put it in .\Arm\Flash. But the file is not visible at the list of Flash Algorithms (Options for Target - Debug - Settings - Flash Download - Add).
Keil referred to this issue as follows: "This happens if Debug Information was turned off at Options for Target - Output."
In my case Debug information is on. I also see that the built FLM binary contains the description name as inserted in FlashDev.c (FlashDevice struct).
What else could cause this?
Thank you
Ari
