Hi
I asked a similar Q a couple of years back and never got around to working on this again. Lockdown is letting me circle back to parked issues.....
Now that I have implemented this I am getting a HardFault as soon as I step in debug mode: I get an IACCVIOL and sit on HardFault. My MPU is not enabled.
Anyone have any idea? I have compared to what others have done (but there is not a lot for STM32F4/related) and don't see what I am missing.
Thanks (& Happy New Year, 2021, an odd year for another odd experience, thanks Covid)
FUNC void FMC_Wait (void) { unsigned int long tmp; unsigned int long tmpreg; unsigned int long timeout; tmp = _RDWORD( 0xA0000158 ); tmpreg = tmp & 0x00000020; timeout = 0xFFFF; while((tmpreg != 0) && (timeout-- > 0)) { tmp = _RDWORD( 0xA0000158 ); tmpreg = tmp & 0x00000020; } } FUNC void SetupFMC (void) { unsigned int long tmp; //set GPIO for ExtMem tmp = _RDWORD ( 0x40023830 ); tmp = tmp | 0x000001FF; _WDWORD( 0x40023830, 0x000001FF ); tmp = _RDWORD( 0x40023830 ); _WDWORD( 0x40020420 , 0x0C000000 ); _WDWORD( 0x40020424 , 0x00000000 ); _WDWORD( 0x40020400 , 0x00002000 ); _WDWORD( 0x40020408 , 0x00002000 ); _WDWORD( 0x40020404 , 0x00000000 ); _WDWORD( 0x4002040C , 0x00000000 ); _WDWORD( 0x40020C20 , 0xCCCC00CC ); _WDWORD( 0x40020C24 , 0xCCCCCCCC ); _WDWORD( 0x40020C00 , 0xAAAAAA0A ); _WDWORD( 0x40020C08 , 0xAAAAAA0A ); _WDWORD( 0x40020C04 , 0x00000000 ); _WDWORD( 0x40020C0C , 0x00000000 ); //GPIOE _WDWORD( 0x40021020 , 0xCCCCCCCC ); _WDWORD( 0x40021024 , 0xCCCCCCCC ); _WDWORD( 0x40021000 , 0xAAAAAAAA ); _WDWORD( 0x40021008 , 0xAAAAAAAA ); _WDWORD( 0x40021004 , 0x00000000 ); _WDWORD( 0x4002100C , 0x00000000 ); //GPIOF _WDWORD( 0x40021420 , 0x00CCCCCC ); _WDWORD( 0x40021424 , 0xCCCCC000 ); _WDWORD( 0x40021400 , 0xAA800AAA ); _WDWORD( 0x40021408 , 0xAA800AAA ); _WDWORD( 0x40021404 , 0x00000000 ); _WDWORD( 0x4002140C , 0x00000000 ); //GPIOG _WDWORD( 0x40021820 , 0x00CCCCCC ); _WDWORD( 0x40021824 , 0xC0C0000C ); _WDWORD( 0x40021800 , 0x88020AAA ); _WDWORD( 0x40021808 , 0x88020AAA ); _WDWORD( 0x40021804 , 0x00000000 ); _WDWORD( 0x4002180C , 0x00000000 ); //GPIOH _WDWORD( 0x40021C20 , 0xC0C00000 ); _WDWORD( 0x40021C24 , 0x00000000 ); _WDWORD( 0x40021C00 , 0x00008800 ); _WDWORD( 0x40021C08 , 0x00008800 ); _WDWORD( 0x40021C04 , 0x00000000 ); _WDWORD( 0x40021C0C , 0x00000000 ); //Enabled FMC Clk tmp = _RDWORD ( 0x40023838 ); _WDWORD( 0x40023838, 0x00000001 ); tmp = _RDWORD( 0x40023838 ); //Config FMC _WDWORD( 0xA0000140 , 0x000019DA ); _WDWORD( 0xA0000148 , 0x01115351 ); _WDWORD( 0xA0000144 , 0x000019DA ); _WDWORD( 0xA000014C , 0x01115351 ); _WDWORD( 0xA0000150 , 0x00000009 ); FMC_Wait(); _WDWORD( 0xA0000150 , 0x0000000A ); FMC_Wait(); _WDWORD( 0xA0000150 , 0x0000006B ); FMC_Wait(); _WDWORD( 0xA0000150 , 0x0004600C ); FMC_Wait(); tmp = _RDWORD( 0xA0000154); _WDWORD( 0xA0000154, ( tmp | (0x0000027C<<1))); tmp = _RDWORD(0xA0000140); _WDWORD( 0xA0000140, ( tmp & 0xFFFFFDFF)); } FUNC void Setup (void) { SP = _RDWORD(0xD3000000); PC = _RDWORD(0xD3000004); XPSR = 0x01000000; _WDWORD(0xE000ED08, 0xD3000000); } SetupFMC(); LOAD %L INCREMENTAL Setup(); //g, main
Debug_SDRAM.rar
Eventually I have worked out that, for some reason (Keil IDE?), the MPU is enabled whilst showing as not enabled. Or, it is an ST issue that is poorly documented. So, I have added MPU initialisation to my debug.ini script, adding a 4G (full addr area) as Permitted. Also, I have to init the FPU as I am using RTX and the _init code between startup and main() fails if the FPU is not enabled.
FUNC void FMC_Wait (void) { unsigned int long tmp; unsigned int long tmpreg; unsigned int long timeout; tmp = _RDWORD( 0xA0000158 ); tmpreg = tmp & 0x00000020; timeout = 0xFFFF; while((tmpreg != 0) && (timeout-- > 0)) { tmp = _RDWORD( 0xA0000158 ); tmpreg = tmp & 0x00000020; } } FUNC void SetupFMC (void) { unsigned int long tmp; //set GPIO for ExtMem tmp = _RDWORD ( 0x40023830 ); tmp = tmp | 0x000001FF; _WDWORD( 0x40023830, tmp ); tmp = _RDWORD( 0x40023830 ); _WDWORD( 0x40020420 , 0x0C000000 ); _WDWORD( 0x40020424 , 0x00000000 ); _WDWORD( 0x40020400 , 0x00002000 ); _WDWORD( 0x40020408 , 0x00002000 ); _WDWORD( 0x40020404 , 0x00000000 ); _WDWORD( 0x4002040C , 0x00000000 ); _WDWORD( 0x40020C20 , 0xCCCC00CC ); _WDWORD( 0x40020C24 , 0xCCCCCCCC ); _WDWORD( 0x40020C00 , 0xAAAAAA0A ); _WDWORD( 0x40020C08 , 0xAAAAAA0A ); _WDWORD( 0x40020C04 , 0x00000000 ); _WDWORD( 0x40020C0C , 0x00000000 ); //GPIOE _WDWORD( 0x40021020 , 0xCCCCCCCC ); _WDWORD( 0x40021024 , 0xCCCCCCCC ); _WDWORD( 0x40021000 , 0xAAAAAAAA ); _WDWORD( 0x40021008 , 0xAAAAAAAA ); _WDWORD( 0x40021004 , 0x00000000 ); _WDWORD( 0x4002100C , 0x00000000 ); //GPIOF _WDWORD( 0x40021420 , 0x00CCCCCC ); _WDWORD( 0x40021424 , 0xCCCCC000 ); _WDWORD( 0x40021400 , 0xAA800AAA ); _WDWORD( 0x40021408 , 0xAA800AAA ); _WDWORD( 0x40021404 , 0x00000000 ); _WDWORD( 0x4002140C , 0x00000000 ); //GPIOG _WDWORD( 0x40021820 , 0x00CCCCCC ); _WDWORD( 0x40021824 , 0xC0C0000C ); _WDWORD( 0x40021800 , 0x88020AAA ); _WDWORD( 0x40021808 , 0x88020AAA ); _WDWORD( 0x40021804 , 0x00000000 ); _WDWORD( 0x4002180C , 0x00000000 ); //GPIOH _WDWORD( 0x40021C20 , 0xC0C00000 ); _WDWORD( 0x40021C24 , 0x00000000 ); _WDWORD( 0x40021C00 , 0x00008800 ); _WDWORD( 0x40021C08 , 0x00008800 ); _WDWORD( 0x40021C04 , 0x00000000 ); _WDWORD( 0x40021C0C , 0x00000000 ); //Enabled FMC Clk tmp = _RDWORD ( 0x40023838 ); _WDWORD( 0x40023838, 0x00000001 ); tmp = _RDWORD( 0x40023838 ); //Config FMC _WDWORD( 0xA0000140 , 0x000019DA ); _WDWORD( 0xA0000148 , 0x01115351 ); _WDWORD( 0xA0000144 , 0x000019DA ); _WDWORD( 0xA000014C , 0x01115351 ); _WDWORD( 0xA0000150 , 0x00000009 ); FMC_Wait(); _WDWORD( 0xA0000150 , 0x0000000A ); FMC_Wait(); _WDWORD( 0xA0000150 , 0x0000006B ); FMC_Wait(); _WDWORD( 0xA0000150 , 0x0004600C ); FMC_Wait(); tmp = _RDWORD( 0xA0000154); _WDWORD( 0xA0000154, ( tmp | (0x0000027C<<1))); tmp = _RDWORD(0xA0000140); _WDWORD( 0xA0000140, ( tmp & 0xFFFFFDFF)); } FUNC void Setup (void) { SP = _RDWORD(0xD3000000); PC = _RDWORD(0xD3000004); XPSR = 0x01000000; _WDWORD(0xE000ED08, 0xD3000000); } FUNC void SetupFPU (void) { _WDWORD(0xE000ED88, 0x00F00000); } FUNC void SetupMPU (void) { _WDWORD(0xE000ED90, 0x00000800); _WDWORD(0xE000ED94, 0x00000001); _WDWORD(0xE000ED98, 0x00000000); _WDWORD(0xE000ED9C, 0x00000000); _WDWORD(0xE000EDA0, 0x0300003F); _WDWORD(0xE000EDA4, 0x00000000); _WDWORD(0xE000EDA8, 0x0300003F); _WDWORD(0xE000EDAC, 0x00000000); _WDWORD(0xE000EDB0, 0x0300003F); _WDWORD(0xE000EDB4, 0x00000000); _WDWORD(0xE000EDB8, 0x0300003F); } SetupFMC(); SetupFPU(); LOAD %L INCREMENTAL Setup(); SetupMPU(); g, main
I will post the full project as I cannot see where to attach in my reply......
Mark
