adc module with lpc2148
hi
i am using ads1255 module with lpc2148
i can able to configure spi and it is checked with loop test
now i am sending commands to register with data for baudrate from uC to ads module and it is setting and configured
i have then checked the number of samples in data ready pin and it is changed
now i am reading baudrate value from register and it is working only sometimes and unpredictable
so having doubt in initial configurations
please anyone send sample code with someother uC also
I am attaching my code for reference
void ads_1255_channel_function(void)
//    SPI_WriteByte(ADS125X_CMD_RESET);DelayMicro(100);//    SPI_WriteByte(ADS125X_CMD_SDATAC);DelayMicro(100);
    ADS125X_DRDY_Wait();
              spiTx[0] = (ADS125X_CMD_WREG|ADS125X_REG_MUX);// 1st command byte
              spiTx[1] = 0;// 2nd command byte = bytes to be read -1
    spiTx[2] = (ADS125X_MUXP_AIN4|ADS125X_MUXN_AIN0);
    SPI_WriteByte(spiTx[0]);DelayMicro(1);
    SPI_WriteByte(spiTx[1]);DelayMicro(1);
    SPI_WriteByte(spiTx[2]);DelayMicro(10);
void ads_1255_channel_read_function(void)
    SPI_WriteByte(ADS125X_CMD_SYNC);DelayMicro(10);
    SPI_WriteByte(ADS125X_CMD_WAKEUP);DelayMicro(40);
              spiTx[0] = ADS125X_CMD_RDATA; // 1st command byte
    SPI_WriteByte(spiTx[0]);DelayMicro(10);
    SPI_WriteByte(spiTx[1]);DelayMicro(10);
    data_rate_u8=SPI_ReadByte();DelayMicro(10);
    sprintf(ext_int_str,"%05x",data_rate_u8);
    LedDisplay(ext_int_str,0,0);Delay1sec(2);
R Sridhar
