Hello.
I'm new to uVision 5 and downloaded the "Driving a BLDC motor with sensorless FOC" example project using the Pack Installer. Using it with the TLE9879EVALKITTOBO1 eval kit. The documentation indicates that the setup files were created with the Config Wizard, however, I don't see the Config Wizard tab at the bottom of my text editor when I open up the source files. I'm able to access the Config Wizard tool via the Tools\Config Wizard V2.2.1 selection, but the tool opens up in a separate window and any changes I make in the wizard do not get ported over into the project. In the Project folder structure, there are ConfigWizard files that were created in the project. Does anyone have any suggestions on what I may be doing wrong or how I can use the wizard to make project changes to the example project?
Thank you.
SRI_Jim said: I don't see the Config Wizard tab at the bottom of my text editor when I open up the source files.
You will only see that tab when you open a header file which uses the 'Config Wizard' format.
https://www.keil.com/pack/doc/CMSIS/Pack/html/configWizard.html
eg,
