initialization of global variable is missing by the compiler
  1. I have that simple code:
 int a = 6;
main {
      DbgPrint("a=%d', a);
when I run t the variable a  should  be 6 but not!!
  1. I have an linux arm a53 simulation environment and I compile c code for aarch64 with arm c compiler - (baremetal version without any additional  libc or CRT included).
  2. I observed that the global variable don't have the values I set for them into the code but random value.  I disable the code and indeed no init of that variable.
Who should  init that variable , no the compiler ? I don't expect CRT to set it . I expect only .bbs section to be set to zero by CRT at runtime stage.
