Hi everyone,
My name is amarr, Present i am using Keil (version 5.31)Tool for editing my project source codes.
My aim is to upload project source codes to GIT HUB directly by using GIT Repository web link to Keil tool for doing this i followed below link and PDF file but no
luck.
https://www.keil.com/support/man/docs/uv4/uv4_ut_usingsvcsmenu.htm
https://www.keil.com/support/man/docs/uv4/uv4_dg_sccmanager.htm
https://community.arm.com/developer/tools-software/tools/f/keil-forum/34339/available-to-push-codes-to-github-with-keil-mdk-5
Can anyone help me for what kind of config settings can i change in keil tool for doing above things?
Thank you in advance.
Regards,
amarr
Are you familiar with using Git and/or GitHub itself - separate from Keil ?
If not, you should probably study those basics first - as that is required/assumed in order to be able to integrate it into Keil.
Personally, I find it sufficient to simply use version control (whether Git or other) at the filesystem level - rather than have to keep re-integrating it into each and every different IDE I use:
https://www.avrfreaks.net/comment/3009321#comment-3009321
Hi Andy Neil,
Thank you for reply,
I know the basics of Git and/or GitHub. Till now everytime i am updating my project files in GITHUB Repo by commit it this become difficult for
every time/every day. But i want integrate Keil with Github repo for whatever changes i do in source code it should replicate in git Repo.
So kindly guide/suggest me to make it from keil.
Thank you.
Like I said, I just do it directly in the filesystem.
amarr said:this become difficult for >every time/every day
Really?
Specifically, I use TortoiseGit - so it's just a couple of clicks to commit/push/whatever:
apart from the benefit already mentioned, this also means that it's not restricted just to things within the Keil project ...
Did you use the Template mentioned in the documentation?
https://www.keil.com/support/man/docs/uv4/uv4_ui_svcs.htm
Yes I used git.svcs template from .../uv4/ folder.
did it work?
No, its not working? Can I do any changes for git.svcs?
Why have you marked your last 2 posts as suggested answers?
amarr said:its not working
Be more precise - "not working" tells us little.
What is happening ?
Are you getting any error messages ?
Are you sure that the underlying Git installation is working ?
Hi andy,
Sorry for that.
https://www.keil.com/appnotes/files/apnt_279.pdf
I config SVCS Config settings like below attached image.
But for updating git repo from keil, we have to link give repo web path to keil?vif yes where we have to add it?
thanks
Again, why are you marking your posts as suggested answers?
The idea is that you do that to identify which post(s) resolved the issue - but your issue is not resolved yet!
You can uncheck the box!
amarr said:we have to link give repo web path to keil?
This has nothing specifically to do with Keil - you are just using Keil to issue the same Git commands that you would do manually from the command line.
When you create or clone your local repository, that's where you set up the link to the 'Remote'
That's shown in section 2 of the "Centralized Workflow Example" in the document you linked.
Again, you really have to understand how to do this manually from the command line in order to tell Keil to do it for you.
