Hi there,
I am trying to invert a matrix using arm_mat_inverse_f32(). I am getting correct results for some martices, but in the code below status3 = ARM_MATH_SINGULAR. status1 and 2 = ARM_MATH_SUCCESS.
Any ideas what is wrong here? Note that det(m3) = -921600, i.e. not singular.
I am using arm_math v1.5.3 on an Atmel SAM E70
arm_matrix_instance_f32 mat1, mat2, mat3; arm_matrix_instance_f32 inv1, inv2, inv3; #define SIZE1 (6) #define SIZE2 (4) float32_t m1[SIZE1*SIZE1] ={ 7.6294, 1.1843, 1.0842, 1.7056, 1.3111, 0.8036, 1.1843, 7.0938, 1.4429, 1.9244, 0.9154, 1.0024, 1.0842, 1.4429, 7.6006, 0.7976, 1.1649, 1.1927, 1.7056, 1.9244, 0.7976, 6.0714, 1.2414, 0.9802, 1.3111, 0.9154, 1.1649, 1.2414, 7.3110, 0.2683, 0.8036, 1.0024, 1.1927, 0.9802, 0.2683, 7.6469 }; float32_t m2[SIZE1*SIZE1] = { 2.4086, -1.7141, 0.9385, 1.9594, -0.4342, 1.3369, 5.1228, 0.3019, -1.9435, 0.3259, 0.0788, 1.3030, -1.8536, -1.3981, 0.0812, -3.1542, 0.2977, 1.2532, -8.8154, 0.4773, -0.6195, 1.2333, -0.1475, 1.1768, 1.6616, 1.9255, 0.8342, -1.4220, -0.6654, 1.0847, 1.0000, 1.0000, 1.0000, 1.0000, 1.0000, 1.0000}; float32_t m3[SIZE2*SIZE2] = { 1.0, 32.0, 4.0, 128.0, 1.0, 32.0, 64.0, 2048.0, 1.0, 16.0, 4.0, 64.0, 1.0, 16.0, 64.0, 1024.0}; float32_t m1int[SIZE1*SIZE1]; float32_t m3int[SIZE2*SIZE2]; arm_mat_init_f32(&mat1, SIZE1, SIZE1, (float32_t *) m1); arm_mat_init_f32(&inv1, SIZE1, SIZE1, m1int); arm_mat_init_f32(&mat2, SIZE1, SIZE1, (float32_t *) m2); arm_mat_init_f32(&inv2, SIZE1, SIZE1, m1int); arm_mat_init_f32(&mat3, SIZE2, SIZE2, (float32_t *) m3); arm_mat_init_f32(&inv3, SIZE2, SIZE2, m3int); // status1 = arm_mat_inverse_f32(&mat1, &inv1); status2 = arm_mat_inverse_f32(&mat2, &inv2); status3 = arm_mat_inverse_f32(&mat3, &inv3);
