Keil uVision: Microchip SAMD21 Series Device Support pack file size of 0 bytes
Recently I tried to install the SAMD21 pack automatically using the latest uVision v5.33 and I failed miserably due to pack integrity check error:
Cannot install Pack Microchip.SAMD21_DFP.3.3.98: Pack integrity check failed
So I tried to download the pack manually and every time I do that I get the empty file (you can see the size of 0 when you press the save button so it is not a problem with the AV I guess)
https://www.keil.com/dd2/pack/#/third-party-download-dialog
I tried other pack for different MCU vendor and everything is fine.
Thanks,
Bogdan
0
