hi. I'm using MDK 4.72 for ARM, and using a tm4c123g
I want to servo control , but i can.
my code this. I applied this DCMOTOR.(because, i can`t find a servo library)
// DCMotor.c// Runs on LM4F120 or TM4C123// Use SysTick interrupts to implement a software PWM to drive// a DC motor at a given duty cycle. The built-in button SW1// increases the speed, and SW2 decreases the speed.// Daniel Valvano, Jonathan Valvano// August 6, 2013
/* This example accompanies the book "Embedded Systems: Introduction to ARM Cortex M Microcontrollers", ISBN: 978-1469998749, Jonathan Valvano, copyright (c) 2013 "Embedded Systems: Real Time Interfacing to ARM Cortex M Microcontrollers", ISBN: 978-1463590154, Jonathan Valvano, copyright (c) 2013
Copyright 2013 by Jonathan W. Valvano, valvano@mail.utexas.edu You may use, edit, run or distribute this file as long as the above copyright notice remains THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. VALVANO SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER. For more information about my classes, my research, and my books, see users.ece.utexas.edu/.../ */
// PA5 connected to DC motor interface
#include "PLL.h"
#define GPIO_PORTA_DATA_R (*((volatile unsigned long *)0x400043FC))#define GPIO_PORTA_DIR_R (*((volatile unsigned long *)0x40004400))#define GPIO_PORTA_AFSEL_R (*((volatile unsigned long *)0x40004420))#define GPIO_PORTA_DR8R_R (*((volatile unsigned long *)0x40004508))#define GPIO_PORTA_DEN_R (*((volatile unsigned long *)0x4000451C))#define GPIO_PORTA_AMSEL_R (*((volatile unsigned long *)0x40004528))#define GPIO_PORTA_PCTL_R (*((volatile unsigned long *)0x4000452C))#define GPIO_PORTF_DATA_R (*((volatile unsigned long *)0x400253FC))#define GPIO_PORTF_DIR_R (*((volatile unsigned long *)0x40025400))#define GPIO_PORTF_IS_R (*((volatile unsigned long *)0x40025404))#define GPIO_PORTF_IBE_R (*((volatile unsigned long *)0x40025408))#define GPIO_PORTF_IEV_R (*((volatile unsigned long *)0x4002540C))#define GPIO_PORTF_IM_R (*((volatile unsigned long *)0x40025410))#define GPIO_PORTF_RIS_R (*((volatile unsigned long *)0x40025414))#define GPIO_PORTF_ICR_R (*((volatile unsigned long *)0x4002541C))#define GPIO_PORTF_AFSEL_R (*((volatile unsigned long *)0x40025420))#define GPIO_PORTF_PUR_R (*((volatile unsigned long *)0x40025510))#define GPIO_PORTF_DEN_R (*((volatile unsigned long *)0x4002551C))#define GPIO_PORTF_LOCK_R (*((volatile unsigned long *)0x40025520))#define GPIO_LOCK_KEY 0x4C4F434B // Unlocks the GPIO_CR register#define GPIO_PORTF_CR_R (*((volatile unsigned long *)0x40025524))#define GPIO_PORTF_AMSEL_R (*((volatile unsigned long *)0x40025528))#define GPIO_PORTF_PCTL_R (*((volatile unsigned long *)0x4002552C))#define SYSCTL_RCGC2_R (*((volatile unsigned long *)0x400FE108))#define NVIC_ST_CTRL_R (*((volatile unsigned long *)0xE000E010))#define NVIC_ST_RELOAD_R (*((volatile unsigned long *)0xE000E014))#define NVIC_ST_CURRENT_R (*((volatile unsigned long *)0xE000E018))#define NVIC_EN0_R (*((volatile unsigned long *)0xE000E100))#define NVIC_PRI7_R (*((volatile unsigned long *)0xE000E41C))#define NVIC_SYS_PRI3_R (*((volatile unsigned long *)0xE000ED20))
// basic functions defined at end of startup.svoid DisableInterrupts(void); // Disable interruptsvoid EnableInterrupts(void); // Enable interruptslong StartCritical (void); // previous I bit, disable interruptsvoid EndCritical(long sr); // restore I bit to previous valuevoid WaitForInterrupt(void); // low power mode
unsigned long H,L;unsigned long degree;void Motor_Init(void){ SYSCTL_RCGC2_R |= 0x00000001; // activate clock for port A H = L = 0; // 0% start not active degree = 0; GPIO_PORTA_AMSEL_R &= ~0x20; // disable analog functionality on PA5 GPIO_PORTA_PCTL_R &= ~0x00F00000; // configure PA5 as GPIO GPIO_PORTA_DIR_R |= 0x20; // make PA5 out GPIO_PORTA_DR8R_R |= 0x20; // enable 8 mA drive on PA5 GPIO_PORTA_AFSEL_R &= ~0x20; // disable alt funct on PA5 GPIO_PORTA_DEN_R |= 0x20; // enable digital I/O on PA5 GPIO_PORTA_DATA_R &= ~0x20; // make PA5 low NVIC_ST_CTRL_R = 0; // disable SysTick during setup NVIC_ST_RELOAD_R = L-1; // reload value for 500us NVIC_ST_CURRENT_R = 0; // any write to current clears it NVIC_SYS_PRI3_R = (NVIC_SYS_PRI3_R&0x00FFFFFF)|0x40000000; // priority 2 NVIC_ST_CTRL_R = 0x00000007; // enable with core clock and interrupts}void SysTick_Handler(void){ if(GPIO_PORTA_DATA_R&0x20){ // toggle PA5 GPIO_PORTA_DATA_R &= ~0x20; // make PA5 low NVIC_ST_RELOAD_R = L-1; // reload value for low phase } else{ GPIO_PORTA_DATA_R |= 0x20; // make PA5 high NVIC_ST_RELOAD_R = H-1; // reload value for high phase }}void Switch_Init(void){ unsigned long volatile delay; SYSCTL_RCGC2_R |= 0x00000020; // (a) activate clock for port F delay = SYSCTL_RCGC2_R; GPIO_PORTF_LOCK_R = 0x4C4F434B; // unlock GPIO Port F GPIO_PORTF_CR_R = 0x11; // allow changes to PF4,0 GPIO_PORTF_DIR_R &= ~0x11; // (c) make PF4,0 in (built-in button) GPIO_PORTF_AFSEL_R &= ~0x11; // disable alt funct on PF4,0 GPIO_PORTF_DEN_R |= 0x11; // enable digital I/O on PF4,0 GPIO_PORTF_PCTL_R &= ~0x000F000F; // configure PF4,0 as GPIO GPIO_PORTF_AMSEL_R &= ~0x11; // disable analog functionality on PF4,0 GPIO_PORTF_PUR_R |= 0x11; // enable weak pull-up on PF4,0 GPIO_PORTF_IS_R &= ~0x11; // (d) PF4,PF0 is edge-sensitive GPIO_PORTF_IBE_R &= ~0x11; // PF4,PF0 is not both edges GPIO_PORTF_IEV_R &= ~0x11; // PF4,PF0 falling edge event GPIO_PORTF_ICR_R = 0x11; // (e) clear flags 4,0 GPIO_PORTF_IM_R |= 0x11; // (f) arm interrupt on PF4,PF0 NVIC_PRI7_R = (NVIC_PRI7_R&0xFF00FFFF)|0x00400000; // (g) priority 2 NVIC_EN0_R = 0x40000000; // (h) enable interrupt 30 in NVIC}// L range: 8000,16000,24000,32000,40000,48000,56000,64000,72000// power: 10% 20% 30% 40% 50% 60% 70% 80% 90%void GPIOPortF_Handler(void){ // called on touch of either SW1 or SW2 if(GPIO_PORTF_RIS_R&0x01){ // SW2 touch GPIO_PORTF_ICR_R = 0x01; // acknowledge flag0 degree += 40; if(L>0) L = 0; // slow down } if(GPIO_PORTF_RIS_R&0x10){ // SW1 touch GPIO_PORTF_ICR_R = 0x10; // acknowledge flag4 degree += 40; if(L<72000) L = L+16000; // speed up } // H = 80000-L; // constant period of 1ms, variable duty cycle}
int main(void){ DisableInterrupts(); // disable interrupts while initializing PLL_Init(); // bus clock at 80 MHz Motor_Init(); // output from PA5, SysTick interrupts Switch_Init(); // arm PF4, PF0 for falling edge interrupts EnableInterrupts(); // enable after all initialization are done while(1){ // main program is free to perform other tasks WaitForInterrupt(); // low power mode }}
