Hello Community, At the moment im writing a Interface to communicate with keil uvision out of a c# application by using UVSOCK. (https://www.keil.com/appnotes/docs/apnt_198.asp)So far all works fine, but now i have to make a few changes in the J-Link/J-Trace settings. For example Change the SN:.(GUI way: OptionsForTarget->Debug->settings->Debug->SN:)As far as i can see no function is provided by UVSOCK to change settings here. But maybe someone has already come a cross a similar problem and has found a solution or i missed a function which is able to do this and u can tell me ? Regardless if you can help me, have a nice day and good luck for your projects. Greets Hannes
Probably helpful:
"Application Note 198Using the uVision Socket Interface"
www.keil.com/.../apnt_198.asp
