Hi
I was using Keil 5 to debug my code on #1 board, somehow the code was kind of stuck, it has no response to reset, and cannot run anywhere, the same code works with no issue on the other self-build board(these two are basically the same), this #1 board works also with no issue earlier today, this situation just suddenly happened. It has no problem with compile, download, enter debug mode.... I`ve drained my brain and cannot figure out what is wrong,,, any suggestions??
Thanks in advance.
I consider that we talk about MDK 5.
My recommendation is to install our todays latest release MDK 5.33:
http://www2.keil.com/mdk5 and to compare if the issue persists.
In case it does, check if for your target an example project is offered by the Pack Installer:
http://www2.keil.com/mdk5/packinstaller/
Then, compare with this project in use.
