I have been using uVision5 for a few months and until recently few days ago, it always stuck at the splash screen when everytime I started the software.
I have done a number of uninstall and installation, but it doesn't seems to work.
Any advise?
This usually happens when you are using a flex floating license, and for some reason your flex floating license server is not reachable or non-responsive when starting your MDK uVision:
www.keil.com/.../4079.htm
HI Chen Tang, thanks for sharing the link and indeed because of this reason, once I put the FLEX_USE = 0, it works.
