I am currently playing about with MQTT using the MDK-Packs::Paho_MQTT pack in MDK-ARM. However, when I try and include the stm32f7xx.h file in my MQTT thread I get an error:
Arm\Packs\Keil\STM32F7xx_DFP\2.13.0\Drivers\CMSIS\Device\ST\STM32F7xx\Include\stm32f7xx.h(171): error: #101: "SUCCESS" has already been declared in the current scope
which is because it is declared here:
typedef enum { SUCCESS = 0U, ERROR = !SUCCESS } ErrorStatus;
in stm32f7xx.h, and here:
/* all failure return codes must be negative */ enum returnCode { BUFFER_OVERFLOW = -2, FAILURE = -1, SUCCESS = 0 };
in MQTTClient.h.
This currently means that I can't include both files. My question is, is there a way to override this (or otherwise fix this) without editing the two header files (as they are "locked" for editing by MDK-ARM).
Regards,
Alex
This is a quality-of-implementation issue of both packages you're trying to combine. No experienced C programmer would ever define enum values like that, because doing so invites exactly the type of collision in the global namespace you're experiencing here. Properly designed components apply name prefixes to all such globally visible names to avoid this pitfall. In C++ one would use namespaces instead --- which are effectively nothing but syntactic sugar that end up doing the very same thing behing the scenes.
So yes, as-is these are impossible to use together. Changing just the headers would almost certainly not work, either, because these enum constants are going to appear all over the sources of the two components, too. This needs to be fixed by either or both suppliers, eventually.
For anyone else that runs into this same problem I have created a pull request for the eclipse-paho project here:
github.com/.../214
that addresses this specific problem (by changing the enum values to use name prefixes as per Broeker's suggestion).
Thanks for the information. I've fiddled with the MQTTClient code to use names prefixes within that enum (as it was the easiest target and didn't require huge amounts of modifications).
Cheers,
You might also raise the issue to ST ...
Broeker said: Changing just the headers would almost certainly not work, either, because these enum constants are going to appear all over the sources
I'm not sure it's actually resolved though ...
fair point.
but the resolution has been identified
